Question about Clarke Power Products Saws
Need carbon brushes for clarke m.n.mt1203 angle grinder
2 Suggested Answers
snor38
  • 118 Answers
SOURCE: Need brushes for Clarke 41/2" Angle Grinder Model
Heyglmars, most times you can take your old brushes to a westlake hardware store, they have a very good selection of brushes in stock. good luck snoe38
Posted on Mar 21, 2011
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
Brushes angle grinder
First try a good hardware store. Take out a brush and take it with you to match it up.
Apr 28, 2014 | Saws
Replacement carbon brushes Ryobi AG402 angle grinder
You can purchase replacement carbon brushes on amazon Amazon com Ryobi carbon brushes. I hope this was helpful. cheers
Jul 12, 2013 | Saws
Brushes for drillmaster grinder
looking for carbon brushes for a drill master model#69079
Jun 09, 2012 | Master Heaters Drill Master 412" Angle...
Why to much sparks in the brushes
Low power and lots of sparks from the brushes is usually indicative of a damaged commutator (the ring where the brushes contact the armature) or burnt or broken windings on the armature. The only fix for either of these problems is to replace the armature.
Apr 28, 2012 | Clarke Power Products 7 in 9 in Angle...
Angle grinder eats carbon brushes
Yes, the rock dust is what's destroying your brushes and armatures. It gets sucked into the rear vent slots and gets to those parts and eats them away quickly. I don't know of any vacuum systems make by Makita but there are some companies that make them for their systems. Blastrac is one that comes to mind but they can be real expensive systems. I don't know of any grinders with sealed brush/armature systems, they have too much heat to disipate. To make your Makita grinders last longer make sure you are cutting with the side of the blade that directs the dust away from the case and try to have a strong airflow blowing the dust away from the grinder to minimize the dust taken in at the back of the grinder.
Jul 15, 2010 | Makita 9005B 5" Electric Angle Grinder
I had been using this grinder for about 2 weeks with no problems. A few days ago while using it it just popped and hasn't worked since.
These are great grinders. I have two of them. One version (more expensive one) has soft start and good overload system. Other version is basic grinder. if it (popped) most likely a short in the motor. Is it possible you got an unusual amount of grinding dust into the grinder? This grinder has a safety feature on the brushes, that keeps from burning up the armature when the brushes wear out. I doubt you've worn out a set of brushes in 2 weeks, unless you've been using it non stop. At least one of the brushes has a small plastic insulating pin inside the carbon. When the brush wears down enough to expose the plastic pin, the spring loaded pops out, lifting the brush from the armature , which opens the circuit. You could remove the brush holders and inspect the brushes. If it is 2 weeks old it is under warranty, and you should return it where you bought it.
Jul 14, 2010 | Metabo ® 12 Amp 9000 RPM Model WE14150...
Carbon brush sizes
They are exactly the same brushes. Part number 316041640 .
Sep 15, 2009 | Metabo WE14-150 Quick Angle Grinder
I have an older clark 4 1/2 inch angle grinder, and am in need of new brushes. have been unable to locate via the web. serial #419888. any possible chance you can lead me in the right direction. ty-david
If you are familiar with 'Heath Robinson'(or not).
What you could do is:
take some charcoal from the fire, and fasion it to the correct shape and fit in place of the brushes,
or
take an old drill, or grinder, or any high drain appliance, with an electric motor, that's 'had it'.
Remove the brushes, and chances are they'll fit.
Cost: Zero.
Have fun dis-assembling your tools:)
May 05, 2009 | Clarke 4 1/2" Grinder
Saws Logo
60 people viewed this question
Top Clarke Power Products Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Clarke Power Products Saw Expert? Answer questions, earn points and help others
