Question about Toshiba TLP 670 Multimedia Projector
I have a Toshiba TLP 670 Projector. It comes on and stays on about 5 minutes, then goes off. I have changed the lamp and cleaned the filter. I don't find anything in the manual about resetting the hours after changing the lamp, so am assuming that it resets automatically. Just before it goes off, a lightbulb icon and 1000H shows up on the screen.
SOURCE: Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Posted on Dec 06, 2007
  • 3422 Answers
SOURCE: Toshiba TLP S30 projector
HI,
Make sure the lamp cover is in place as it has a plunger on it which closes a switch . If the switch is open you will never power on. With the cover remover you can manually activate the switch too and it will power up.
For more troubleshooting steps you can see the user manual from HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 27, 2008
  • 105 Answers
SOURCE: how to reset lamp timer for a TLP 671
Hi there folow the link bellow for the manual
Regards Al "alstech"
http://www.fixya.com/support/p147512-toshiba_tlp_671_multimedia_projector/manual-15037
Posted on May 26, 2009
heathgr
  • 442 Answers
SOURCE: how to reset lamp hours
Supposedly the lamp has a chip that keeps track of the used time. The manual says to check in the instructions that came with the lamp. Others say that LG will not reveal how to do it. Perhaps you could ring LG service and give them your machine serial number and request that as the owner you want the correct information.
Posted on Apr 11, 2011
ViscamTech
  • 528 Answers
SOURCE: We have like a
Rotate the lens to focus the image.
Posted on Sep 10, 2011
How do i change filter
https://www.google.co.uk/search?q=Toshiba+TLP-X3000+filter+change
Click the first link. Read page 52.
Honestly.
(Page basically says, unplug projector, pull the filter off from under the lens (it's hinged at the front of the projector), and either clean that or unpack the new one, and clip the cleaned/new filter back on in the obvious reverse manner...)
Jan 30, 2014 | Toshiba TLP-X3000 LCD Projector
Toshiba TLP s30 projector identification part
http://www.nextag.com/toshiba-tlp-s30/search-html
Mar 28, 2008 | Toshiba TLP S30 Multimedia Projector
Toshiba TLP projector identifiation part
You need to check lamp again, it may be not well mounted.
My TLP-S10 lamp will not stay on after a couple of moments.
Is the fan working. Check fan. Very likely the device overheated. If fan is working the air filter might need to be cleaned. See you manual how to clean filter and reset the filter cleaning counter so that the device can work properly again.
Feb 17, 2011 | Toshiba TLP-S10 Multimedia Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba tlp670u
This is due to filter problem you can clean the filter other and put it back this one reason.
Another one it might me problem with cooling fans any one of the fan speed will slow or failed. Please check the same and replace.
Regards,
prakasam
Mar 05, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Toshiba TLP671 - lamp red LED
It is problem with temperature. So please check with filter and clean it. Other wise check any of the fans are not functioning properly. So check the same and replace
Nov 14, 2007 | Toshiba TLP 261 Multimedia Projector
Toshiba TLP 670 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
