Question about Cameras
My Canon PowerShot SD750 (digital elph), when I turn it on, it reads "Memory card error" at the top. It shows a picture in the viewfinder, and all other functions seem to work but it will not take a photo. Do you know what I need to do to fix it? (The memory card is IN the slot correctly and the battery is charged)
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
My memory card keep on showing "memory card error". how can I save my pictures in that memory?
You could use a separate card reader to download your pics. Then, format the card in the camera.
Jun 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon ixus 75 displays a black screen when in the shoot mode,this happened suddenly while taking a number of pictures,although I can still veiw pictures on the memory card.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do i make the resolution high on a Canon Powershot sd750 digital elph
Go into the picture taking menu and find a setting for picture quality...choose the largest one.
Dec 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Sep 03, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
All of the functions of
Don't hit it. With the camera on, have you tried pressing the DISP button once? It's the bottom button on the back of your camera.
As a side note, the DISP button was intended for digital cameras with an optical viewfinder (something the SD750 and newer elphs no longer have). The idea was to allow the user to manually turn the display on or off as desired to save batteries, and then just aim the camera through the viewfinder. I'm curious as to Canon's justification for including this button on their newer cameras that do not have a viewfinder?
Mar 06, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card Error
Use USB card reader&writer to retrieve the pictures directly from the card.
Nov 28, 2007 | Canon PowerShot SD700 IS Digital ELPH /...
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
