Question about Air Tools & Compressors
I have a jumpnstart model jns1880n. i got as a gift and has never been out of the box, I plugged in the charger and the light on the left said remove charger immediately. What can you tell me about this? Thanks Terry
3 Suggested Answers
PuerkoNess
  • 275 Answers
SOURCE: charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Posted on Mar 10, 2009
deme-tri
  • 90 Answers
SOURCE: When plugged into the charger the throttle light
try changing the battery,
or check the water.
Posted on Dec 01, 2009
MyLenova T420 not carging
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in themon that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
TroubleshootMag Safe adaptors
http://support.apple.com/kb/ts1713
Nov 27, 2013 | Lenovo 3000 Y410 Laptop
I really hate waste to the environment but still want to wrap gifts for my family. Any ideas for alternatives?
Here are some ideas that will save the environment as well as some money:
- Reuse gift bags from previous gifts
- Use grocery bags that are plain and unused and decorate them with ribbons, colors etc
- If you have any plants pots or boxes around the house that you don't need, you can put gifts in there and use tissue paper to pad it out.
Feb 25, 2013 | Event Planning & Celebration
Nyko charger won't charge
Had same problem with blinking lights and not charging.
Plug charger base in (blinking lights), remove controllers, and plug USB cable into front charge slot (behind hinged panel). This reset charger base and lights stopped blinking. As FYI - the USB was connected to other device (charging it). Add the controllers and correct charging lights show up - including the controller 1 and 2 symbols. Controllers now charging.
Feb 07, 2012 | Nyko Charge Station 360 For Xbox 360
Why can't I get my Jumpnstart jns188on 12 volt to charge? It has never been used and the light always says disconnect when I try to charge it? I call the 800 # and no one ever answers the phone. This is...
How long has it been discharged?
If more than 5-6 months, you may need to change or charge the battery outside the Jumpnstart.
The voltage of the battery should be over 10.5 V.
Jun 08, 2010 | Electrical Supplies
Hi, Had the bike 2 weeks (birthday gift), not been...
If you start a bike often for just a minute or two over and over again you probably fowled your spark plugs. Replace them and try starting again. If you are worried about the battery, purchase a quick disconnect trickle charger that monitors the battery and only charges when it is needed. A quick disconnect plug is left on the battery which hides on the bike making for quick take offs and plug ins.
May 20, 2010 | Motorcycles
I received a digital camera as a present & that was bought new . Still in box But not able to return because the gift was gifted anonymously I cant return to store for another Because I have no idea...
Hi Luawim,
The camera that you have was a Sanyo VPC-T700T Digital Camera.
You can purchase the unit charger on this link I pate here below.
Let me know if you have any more other concerns.
Thank you for using fixya.
micro-
Dec 12, 2009 | Sanyo Cameras
L830 wont charge
it is possibly the battery itself. i have a two batteries for this camera one of them has this problem orange flashing light and doesn't charge and the other works fine. You might need to get a new battery. Good luck
Oct 11, 2008 | Samsung Digimax L830 Digital Camera
Battery won't charge/no power to unit
Charger seams defective. get new charger and try.
May 29, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Air Tools & Compressors Logo
458 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
