Black screen at startup with only mouse showing
Black Screen on Startup.
Did you try " Last known good configuration at start up. If after boot you press the F8 key where you said you went into safe mode, did you try to load the good known config. It sounds like you have a corrupted registry.
Jul 14, 2009 | Acer Computers & Internet
Canon SD1000, screen blacked out and takes black pictures
try taking the batteries and memory card out let it set and put everything back in it ang cut it on
Jun 18, 2009 | Canon PowerShot SD1000 Digital Camera
Menu screen is black
That sounds like your video card is going out on your computer. You will have to get that replaced and then things will work properly.
Jun 10, 2009 | Microsoft Age Of Empires II: Conqueror 2.0...
Key board not working
It's a hardware issue,
Maybe RAM or hard drive..
Did you get it used? If so the password was set b4 you purchase it, and will not show up when you type,,,It stays hidden.
Your getting this screen because there is a hardware failure. Fix the problem and you wont need the BIOS password.
Press<esc> to enable startup message, This should give you more info on the problem.
Mar 01, 2009 | HP Pavilion dv9000z Notebook
Acer laptop screen is black when I turn it on
press f8 at system startup and boot into safe mode.. then uninstall the device.
Jan 18, 2009 | Compaq Presario X1000 Notebook
Aspire one black screen but mouse appear
Hi Giannluca,
when you turn it on, does it show startup information? E.g. BIOS screen on start-up, windows loading etc? If not, try this:
Hold down the power button for about 10 seconds when its turned on. This should power of your laptop completely, then try turning it on again and let me know what it does.
Regards Ronnie
Jan 08, 2009 | Acer Aspire 4315 Notebook
Screen stays black
Startup while tapping the F8 key,this should open the startup options screen,Select start up in VGA mode,If that works,then you need to update the video drivers
Jan 07, 2009 | Toshiba Satellite L305D-S5895 Notebook
Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Jan 01, 2009 | Dell Inspiron 6400 Notebook
Screen flashes and goes black when you move mouse
some virus or spyware would have been the cause for tat...
go to start and then run,
there, type msconfig n press enter
in tat msconfig window, try clicking startup tab, there, try to remove tat virus startup, which would have been the cause for ur problem..
after tat restart and check, if it is solved
Jul 20, 2008 | IBM ThinkPad 770 Notebook
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
