About the message falta NTLDR
Can I you to resolve problem abut the message falta NTLDR
  • bakersfield May 06, 2008
    can i you about the message falta NTLDR
    Sergeant:
  • 221 Answers
Here is a website that gives you several ways to troublshoot and fix your problem.
http://www.computerhope.com/issues/ch000465.htm
Posted on May 06, 2008
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
How to fix a NTLDR is missing error
Fixes for NTLDR Errors
Apr 06, 2012 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Recovery on presario 1692 NTLDR is not responding
Plz check the below link from HP. It will help you in resolving the issue. ?Missing NTLDR? Serious Error Message Appears During Startup http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00213449&cc=us&lc=en&dlc=en Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 24, 2010 | Compaq Presario 1692 Notebook
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
NTLDR is missing
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Ntldr missing error
Ntldr is the Operating System bootup file. To boot into Windows, Ntldr file is must..
IF you have the Operating System disk with you, do the OS repair. This will resolve your problem...............
Sometimes, OS disk might be problematic, in such cases, you need to go with another disk to reload the Operating System.
Jun 21, 2008 | Dell Microsoft Windows XP Home Edition
I have a compaq presario notebook pc v5305wm, it has a virus, we run the recovery disks, but when it restarts it says that NTLDR is missing. what do we do next
start sys and press F8 KEY go to safe mode.
run chkdsk
if u have recovery disk go to recovery conole and type scandisk /all
Apr 02, 2008 | Computers & Internet
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
