Question about Air Tools & Compressors
Ve a black max 20 gallon air compressor. It is 8 years old but, I have not used it much. It will not start,
    Problem Solver:
  • 5 Answers
Is it electric or gas,? If the motor turns when it is free of the compressor then the compressor (cylinders and valves) could be frozen up. Try to turn it by hand. Try a little WD 40 in the cylinders let it set for a while. When was the last time you used it? If you got moister in it you may have trashed it.
Posted on Aug 26, 2010
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
What grade of oil do air compessors use
iso 32 // 30wt. compressor oil, or no additive mineral oil, never use automotive oil in a air compressor
May 06, 2014 | Eagle C5160v1 - Single Stage - 5hp 60...
Air compressor won't start
does the motor just buzz when you switch it on? if so renew the start caacitor
Mar 09, 2014 | Mi T M Mi-T-M AC1-PE15-20M Electric...
Bottom screws on Husky 20 gallon air compressor
You need to check the pressure shut off switch and the capacitor on the motor.
Jun 10, 2013 | Air Tools & Compressors
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Compressor will not build pressure
It sounds like it is not getting enough electricity.
Try plugging in to an outlet on its own circuit without an extension cord. make sure the circuit is rated for your air compressor. If it is on a circuit with other appliances, refrigerator, lights, ect. try shutting them all off before turning on the air compressor.
Good luck
Aug 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
1 HP 3 Gallon Air Compressor does not build up pressure.
it sounds like the regulator is out of whack turning down increases air pressure. make sure there is no leaks
Jun 28, 2009 | Air Tools & Compressors
Brand new Black Max 5 gallon wont run
Unplug the compressor power chord. If you can turn the flywheel, then nothing is stuck. Plug in the power chord and try the compressor again. If it does not work, return the compressor for a replacement.
If you can't turn the flywheel, then something is stuck, return the compressor for a replacement.
If you can't return the compressor for a replacement, then try to take it apart to locate the problem and fix it.
Jun 10, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
83 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
