Question about LG WM-2277HW Front Load Washer
Child lock is stuck...can't open my washer front loader door
SOURCE: LG 1480fhd
In my case this problem was caused by a broken handle in the door assembly. I agree with dovi that you can release the catch from inside the machine if you remove the soap dispenser unit. You can then remove the door and disassemble it to see if the plastic trigger is broken.
If the door handle is broken you cannot exert any force on the metal catch - you think you are triggering the mechanism but you are not.
Posted on Nov 17, 2007
  • 351 Answers
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
  • 1294 Answers
SOURCE: how do i remove child lock on samsung front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Mar 05, 2009
  • 38 Answers
SOURCE: RE: Front loader drum stuck
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Mar 14, 2009
  • 1294 Answers
SOURCE: washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Posted on Mar 27, 2009
Hi,I have lost the user manual for my samsung front loader washing machine IPX4 model www60j426hs and the lock sign stays on. It is stuck and cant change programme. What can I do?
seems as if the washer is in child lock mode pressing and holding a key related to the child lock for four seconds will unlock the washer and allow you to use the washer again
Feb 26, 2017 | Samsung Washing Machines
What does the code de stands for
On front-load washers, it can stand for "door error", meaning the main control board thinks the door is open. If the door is actually closed and the de error won't clear, the electric door lock could be shorted, giving a false signal to the main control board. On the Samsung top-loader, it means a "child lock error" has happened. On that washer, you will see "CL" or "DE", the washer will auto-drain and an alarm will sound. To clear the error, close the door, turn off the power, then turn it back on.
Aug 21, 2015 | Washing Machines
My neptune frontend loader will flash the door lock for 2 seconds and then it will go off when ever i start the machine, i think my child opened it with out turning it off.. is something broken
HI- It is possible that the door lock was damaged if someone forced it open mid-cycle. The machine will not cycle unless the door lock engages. Will probably need a to get a Tech out to have a look. Good luck.
Sep 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
My front load washer has the door lock stuck and the door is open
When this happened to our front loader washing machine, we had to unplug the appliance, wait, then replug it to reset and unlock the door.
Feb 10, 2010 | Electrolux EW1000i Front Load Washer
I can not open my front loader door i think it has the child proof lock on iit is a LG
THE MACHINE HAS A PROBLEM WITH THE AUTOMATIC DOOR RELEASE THAT SHOULD UNLATCH THE DOOR AT THE END OF THE WASH CYCLE, THIS LATCH SOLENOID MAY BE DEFECTIVE OR STUCK
Sep 29, 2009 | Washing Machines
LTF6700FS - (affinity) front loader - door lock will not engage - latch looks fine and child safety feature is not on
Sheck the hinche if is twist or pull that the most comon problem. If is that, disconect the door ahd replace the hinche. If the hintch is OK sheck the lock set up if is of place. Some time is being forced to open or to close it and bend the lock clip.
Aug 11, 2009 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Mar 02, 2008 | LG WM1812C Front Load Washer
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Kenmore Front Loader stuck in "LOC" and every button produces "ERR"
Look for the 2 buttons on your that have a lock symbol.  Pushing & hold both for 3 seconds.  This toggles the child proof mode.
Nov 20, 2006 | Fisher and Paykel Fisher Paykel Intuitive...
LG WM-2277HW Front Load Washer Logo
114 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
