Should be simple
I want to play audio from cable tv thru unit
  • 4 more comments
  • Anonymous May 06, 2008
    low volume
  • rand18 May 23, 2008
    Similar issue: I have an optical audio cable from TV to entertainment system, and cannot hear audio through entertainment system. I have cycled through the various unputs on the entertainment system, it appears TV/AUDIO is the right input, yet no audio. I've tried to find an audio output setting on the TV (a Bravia), thinking I might have to set the TV to output audio through that port, but unsuccessful.
  • tar33az Nov 29, 2008
    I unplugged the speakers to take home and now when plug back in they do not work.
  • fjcordima Dec 28, 2008
    i have a bose 321 series ii system and am having trouble with low volume from all sources. i have to put the volume to about 30 to hear anything. why is this? has anyone else had this problem? if so how did you fix it. i went through the setup disc three times, verifyed all connection were correct and secure and did a system reset and still low volume issues. any help would be appreciated.
  • Anonymous Mar 08, 2009
    TOSHIBA TV HAS WHITE, RED AUDIO CABLE HOOK UP, I'M PLUGGING INTO CABLE INPUT JACKS
    SO NOW WHAT?
  • ned4spd May 11, 2010
    are you using standard AV connection which is (red, yellow and white) cable connectors or component video, which is (red, blue and green) cable connectors or are you using digital/optical.
The color of the connectors is not as important as where they are plugged in. I have tried all possible connections
Posted on May 08, 2008
Why does disc tray open randomly Samsung ht-em54c
I had the problem of the disk tray opening and closing randomly but finally fixed it. I went thru a number of steps so I don't know which combination or individual step fixed it but I think it was changing the HDMI cable from the TV to the Blu ray player that finally fixed the problem. Previous to that I had removed the disk player and got the audio to work with only the TV and used one of the HDMI inputs as the output from my PC. That way I could play DVDs on my PC and run it thru the player to get audio in the speakers and video on the TV. Every once in a while the tray would try to eject (even though the player was not there). Finally I changed the HDMI cable to an older cable, the one between the TV and the player and it started working! I then put the disk player back in the unit and it all worked, everything!! Good luck!
Jul 22, 2014 | Samsung HT-X50 System
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
Dvd/vcr recorder magnavox model mwr20v6, i got probelm hooking up my dvd/vcr recorder to my cable converterbox an tv , because i broke the antenne/ out socket on the back of the unit, how can i get it to...
Hi,If I understood correctly you broke antenna out socket of Cable box..ok no problem,your TV and cable box should have other jacs/socket for this connection as well..
Take the A/V output of your cable box into TV possibly with RCA cables..than you can select the channel thru Cable box on TV ..(AV mode needs to be selected on TV )
** in order to listen and watch your
magnavox DVD 's "2xRCA audio" and "1x RCA Video" cables "OUT" should go to Tv or Cable box "IN" connections separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected ) (audio will come thru Receiver and TV.)
Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action if you wish to listen or RECORD a program on your TV on
magnavox
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV or Cable box .( every TV -cable box has different type of Audio out jacks )
** to "iRCA nput or "Optic Cable input"
of your
magnavox (whichever you want ,based on the necessary cables on your hand )
There you go..Tv/Cable box video and sound are both on the
magnavox for recording..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 15, 2011 | Televison & Video
I can't get video out to TV from Wii video input on receiver. Wii is connected to AV5. Video to TV is thru HDMI out on receiver to HDMI in on TV. I can port the audio but get no video
Hello there,
ok the setup you are using is a Receiver, TV, and Wii unit .
Step 1: plug one HDMI cable into the back of the Receiver unit on slot 2 name on it is called HDMI out jack
if looking at the back of the unit this slot is 2nd from the top left
Step 2: now plug the HDMI cable into the TV this is the cable you just plugged into the Receiver
TV done
Step 3: Wii Setup move the Yellow,White,Red cables over to the right if looking at the back of the unit 2 spots name for this group is called AV out Jacks .
Wii Done
now use the right input channel for this group and you should now See Wii playing .
Thank you and don't forget to Rate
Jan 26, 2011 | Yamaha RXV467 Receiver
To play laptop thru samsung tv I am attempting to play laptop movie thru tv. I have tried the rca y cable with 3.5 mm plug from headphones of laptop to red and white audio in on the samsung tv., no sound....
So you are connecting the laptop to the TV using VGA port of the TV, right? To get sound in the PC input mode, you need to use the PC audio input jack (green jack, mini 3.5mm jack) not the RED and White RCA audio input, they are for Composite Video AV inputs. That is how I have my laptop and TV setup to watch Netflix.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jun 16, 2010 | Samsung LN52A850 52 in. LCD HDTV
Audio muffled when playing back video tape
Have you tried using a wet type head cleaning tape? If not, run one thru at least 3 times.
Feb 05, 2009 | Sansui COM3101 13" TV/VCR
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Mar 11, 2008 | JVC HD-56FN97 56" Television
No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Jan 04, 2008 | Denon AVR-3200 Receiver
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
197 people viewed this question
 Grubhead
Grubhead
