Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 runs for an hour then pic goes out
About four weeks ago, I had the tv on for about 3 hours and suddenly the picture started having bright white flashes in it and then the fan died down and picture went to black (still had sound). I waited for about a minute and then the wound back up and picture came back on. Worked great for about 15 minutes and then did the same. Since then this is what it continues to do. If I turn it off before the pic goes out and leave it off for about ten minutes, I can view for about 30 minutes before it starts happening again. RCA tech said it was my bulb. I replaced it and it still does it. Can you help me?
thanks!!
  • 2 more comments
  • olarzaga May 06, 2008
    can the lamp power supply be replaced as easy as the lamp?
    do you think the problem with my tv is the lamp, not the power supply?
    because i already know what lamp unit my tv needs. In Fact, I just bought it
    please reply
    oal
  • olarzaga May 07, 2008
    I want you guys to know that I really appreciate your help!, but you can understand the amount of frustration experienced so far.
    I have a couple of questions:
    a) after replacing the lamp, should I leave the TV on for at least a 24 hrs period?
    b)what are the symptoms for a TV that needs a new power supply rather than just a lamp replacement?
    thanks
    the DLP lamp unit number of my TV is 265103
    a) can I use the instructions link you sent me before even thought that part number is not mentioned there?
    b) can you send me info regarding power supply replacements (instructions and parts availability)?
    thanks again for your kind help!
    Genius:
  • 1,665 Answers
Its power supply may be faulty
Posted on May 06, 2008
  • 3 more comments
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos May 06, 2008
    Determine Your DLP® Lamp Unit Part Number
    use the following link to find parts available
    http://tv.rca.com/en-US/DLPFindLamps.htm
    Kleanthis Mavropoulos May 07, 2008
    According to the symptoms referred, lamp replacement will restore the regular operation. See instructions at link below
    http://fixyourdlp.com/blog/?p=3
    IMPORTANT: The bulb should be handled with a clean cloth to avoid any dirt or oil. Our hands are naturally oily…this is a no-no for these lamps. It doesn’t hurt to do a final wipe with a clean, non-abrasive, lent free cloth before reinstalling your lamp. Alternatively, you can wear a pair of latex gloves
    Also
    http://tv.rca.com/en-US/DLPRepairGuide.h...
    When should the lamp be replaced?
    You probably need a new lamp if there is no picture, but you can hear audio and the power light on the front of the TV does the following; blinks, pauses for about a minute, blinks again, pauses again, and then flashes for about 1 minute. These symptoms may also occur if the lamp unit is not seated properly or the lamp unit access door is ajar
    I dont think it is necessary to leave tv on for 24 hours.
    A faulty power supply may cause abnormal operation as it may produce ripple or unstable or interupted output depending on the specific fault.
    Here is a DLP lamp unit number of your TV link
    http://www.lcdprojectorlamp.net/265103-B...
    See chapter 5 page 61 of user guide for more information.
    I dont believe that power supply section can be found as complete part to be replaced.
    This would also raise the repair cost too high.
    It better must be inspected or tested by authorized personell and repaired if necessary.
    In general replacement of electrolytic capacitors over 100 V on its board may correct some problems of old TV sets.
    In some cases looking for cold solders at board bottom and resoldering components solve problem without component replacement.
2 Suggested Answers
SOURCE: RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Posted on Sep 05, 2007
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
Picture occasionally goes out, still have sound when this occurs and then the picture will come back on after a while. When the picture is out the lamp is off. Hd61lpw42 RCA DLP TV
Souns like the Lamp is going out ,If you have never replaced Lamp then that is what your Problem is Mats has them for $99.00 1-800-628-1118
Nov 06, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
I'd like to know where I can get a replacement wire to connect the lamp ballast to the J4 input in my rca HD61LPW42 rear projection TV. I've gotten no response to an email I sent RCA a week ago. These...
hey mcd5brady, what was the solution to your last problem w the tv? ( replaced bulb and ballast but still no picture) my tv has same problem and dont know what to do next. any info on a solution would be greatly appreciated! post back or email. dellbino@aol.com
thanks
Jan 09, 2010 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HDTV
have u tried a new bulb. as the bulb aproaches the end of life is tends to do thiis i see this all the time at the shop... bulbs however not a cheap item. how old is the set has the bulb ever been changed how much is the set run average life of a bulb is 3000 to 5000 hours
Feb 15, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
RCA F27442: no picture.
you may have bad solder connection in the horiz.countdown section.
you may also have a GEM Star module bad.
Nov 06, 2007 | RCA F27442 27" TV
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Picture flickers, loses color, goes green, white, and negative, then TV turns off.
the unit has a bad color wheel.rca has seen this problem before.The color wheel has a bad bearing which over time can seize causing the single color you see.Keep on them they know it is defective
Mar 19, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Intermittent picture
Most likely your lamp needs to be replaced as that will cause the intr. picture issue. The color wheel will also have to be replaced. The color wheel is only available with the light engine which is part# 263223 and the lamp part #260962
Mar 05, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
RCA HD61LPW42 61" Rear Projection HDTV Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
