Question about Maytag Dryers
Flame ddoes not stay lit longer than ten seconds. taking hours to dry a light load. what needs to be replaced?
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 29, 2010
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
Jan 01, 2010 | Maytag Dryers
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
Beko SCG 7521 gas cooker flame won't stay lit in oven.Once you light the flame in the oven & hold in the oven button for the recommended 10 secs it cuts it's self off when you release the oven...
bloody hell that is so scarey i have the same problem and its round about the same time yours went funny if you have a solution can you let me know as im looking for the answer myself klass-a@hotmail.co.uk
Oct 08, 2009 | Ovens
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Flame wont stay on and have replaced the flame sensor
You have a limit switch that is tripping. I bet it is the flame roll out switch that is very close to the burners. You can bypass this switch to check if it is the one causing the problem by removing the two wires going to it and installing a small jumper wire between them. If the unit starts up, then that's the problem and if not, check all of them. But that's pretty much the only thing it can be. But, you need to double check that the unit is being told to come on and not cutting out intermittently. I doubt it though!
Mar 23, 2009 | American Standard 2083.102 Standard...
Dyer LSG7804ABE Gas Stackable very little heat
self help is right .first i would try a load with out the ducting.if you have good air flow and still didn't dry[because now youv'e elimanated the house venting as a possiable.replace your coils
Jan 02, 2009 | Maytag LSE7806A Top Load Stacked...
Whirlpool ggw9250pwg
Is there an issue of goin to or from LP (propane) to Natural Gas?? The orfice and metering screw on the valve will need to be adjusted.
Jan 13, 2008 | Whirlpool GGW9250PL Gas Dryer
Dryers Logo
135 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
