Question about Panasonic Panafax UF-9000 All-In-One Laser Printer
Setting IP address configuration for a UF 8000 printer.
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: printer unable to obtain IP address
Reset the TCP/IP information. To do so, Turn off the printer power. With the cartridge door open, hold down both cancel and continue buttons and power the printer on. Hold the buttons until the lights cycle. The TCP/IP information should be cleared. Wait a few minutes.The printer should pick up a new IP address from the network, or should set a default IP. Press the Continue button to print a new test page, and you should see the new address.
Posted on Mar 26, 2008
  • 61 Answers
SOURCE: HP LaserJet 3055 unable to save IP setting
i can solved this problem please give me one chance
Posted on Jul 24, 2008
tech435
  • 284 Answers
SOURCE: Enable Scan on UF-8000
to scan from a uf8000 you need the ifax/scan key no other way to do it and a memory card doesnt help
Posted on Sep 11, 2008
leroyal
  • 2120 Answers
SOURCE: User name an password required
There is none. Try the action below:
press
function
7
monitor key slowly 4 times
6
Scroll down to password clear
set
stop
If that doesn't work, choose SHIPMENT SET
set
wait for machine to initialize
Posted on Feb 24, 2009
Loading software for network asking for IP address
Usually you can run a report on the printer that will show you the IP address it is using.
Mar 26, 2014 | Panasonic UF-8200 Panafax Panafax UF-8200...
Try to connect the hp laserjet 8000 to network, since we connected with static ip, how could I change to dynamic ip?
First, why would you want a printer with a dynamic address? Do you have one reserved in the dhcp scope for it? Do you have the printer named in DNS? Printers are much easier to deal with when they have a static address, they're always in the same place on the network.
All that said, browse through the menus till you find the network setup find the IP menu and set it to automatic. Very simple. Make sure to save your configuration change.
Oct 24, 2013 | HP LaserJet 8000 Printer
Uf 9000 ip address
Just wondering if you've found a solution. I'm trying to do the same thing on our uf-9000. Any help would be appreciated.
Panasonic technical support is not good.
Oct 21, 2013 | Panasonic Panafax UF-9000 All-In-One Laser...
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Hi Guys I hae set up IP address and other network related setting. I can't ping to the printer. Not able to get automatic IP address from the DHCP no ping.
Every network printer or print server has a unique IP address associated with it. This address is either configured manually or set using an automatic network protocol such as the boot protocol, reverse address resolution protocol or zeroconf. You can normally find the IP address of a printer on the printer's control panel or by printing the configuration page. Select the printers and faxes tab from the control panel. Right click on the printer those you want to find the IP address and click properties. Then click on the ports tab to display the IP address of your printer.
Nov 25, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
Panasonic uf-9000
Function
71
set
keep pressing set until you get to ip address
key in with the keyboard
Mar 09, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
press
function
7
6
set
stop
set
Feb 24, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I followed this suggestion and now the IP address is 0.0.0.0. I can not get to the printer setting. I don't know if the DHCP setting still remained as static instead of dynamic. ANY SUGGESTION?
I had the same problem, after removing the DHCP settings, maybe for an error during the configuration the printer didn't assume the new IP address and it resulted 0.0.0.0 from the configuration page.
No way to connect to the printer until I did a network card reset following this procedure:
7. Network Card Reset:
a. Turn the printer off.
b. Open the front cover.
c. Hold down the Continue and the Cancel button while powering the printer on.
d. Release the buttons when the Error light (bottom light) stays on solid.
e. Close the front cover and the printer should return to a READY state.
f. Press and release the continue button to print a network settings page.
g. On the page that prints verify the following:
�� Status = Not Connected
�� Active = Yes
�� DHCP,BOOTP,RARP Enabled = Yes, Yes, Yes
�� Address Source = Manual
�� Address = 0.0.0.0
The printer took a new IP address from the DHCP server.
Since my goal was to set a fixed IP address, I entered the printer configuration through Internet explorer, typing the newly assumed IP address and going to TCP/IP settings where I removed The 'Auto DHCP' and I set the IP address I wanted.
Oct 20, 2008 | Dell 1710n Laser Printer
Jul 05, 2008 | HP LaserJet 3055 All-In-One Printer
Getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Mar 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Panasonic Panafax UF-9000 All-In-One Laser Printer Logo
269 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
