Have just purchased an officejet 4300fax today .In setting up, I removed tape and cardboard,It continues to tell me the paper is jamed I remove and reset same message appears???
    Problem Solver:
  • 16 Answers
It problem related to mechanical assembly , contact any hp technical expert.
Posted on May 06, 2008
Can not feed paper
First try moving the switch manually to reverse. The machine should start. This may cause some paper to appear in the slot where you place the paper to be shredded. If it doesn't start, your problem may be more serious or complex and you should get in touch with the Staples store where you purchased it.
It may be that the paper you are trying to use is too lightweight. Try inserting a piece of cardboard (SLOWLY SO AS NOT TO LET THE BLADES CATCH THE CARDBOARD - LETTING IT CATCH THE CARDBOARD MAY BE BEYOND THE UNIT'S CAPACITY). If this starts the shredder, quickly remove the cardboard. If it continues to run (cycle), you may have had some paper blocking it.
Hopefully this has done the trick and everything now works. If not, talk to the Staples store where you bought it.
Jan 08, 2014 | Staples Cross-Cut Shredder
I received a paper stall message on my brand-new-today HPOfficejet 5600 but I had not installed any paper! What should I do now?
With the power OFF, make sure the print carriage can move freely side to side.
Check the tray area for cardboard and tape.
Press the ON button after you have removed all packing materials.
Feb 17, 2011 | Office Equipment & Supplies
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Paper light on continuously after cardboard was tried to be fed through - all clear, but light remains onl
There is a sensor that is pressed by the presence of the paper to tell you that there is paper in the printer. With the cardboard going through it, the sensor may have got press excessively and has got damaged. What to do now?? Try to locate the paper sensor near the rollers that pull the paper through. Remove it and replace with exactly the same specifications.
Nov 09, 2009 | Brother HL-2040 Laser Printer
HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Nov 02, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Paper won't feed into printer
I have taken a piece of cardboard, like the ones you get with a new shirt, size it to 8.5 x 11, and tell the printer to print a test page. hand feed the cardboard thru, and most times it will clean out the residual paper pieces stuck in the internal rollers. I have used this method several times and was successful 99% of the time. It isn't rocket science, but It may work. You will probably have to push the cardboard thru, but do not force it to much. It will not go thru easily on its own. Just a suggestion.
Jun 17, 2009 | Epson Stylus CX3810 All-In-One InkJet...
C5280 print cartridges can't move
Open the front door and look inside, where the cartridges are installed. Make sure that the carriage is moving freely and doesn't get locked.
May 05, 2008 | HP Photosmart C5280 Printer
HP Officejet 7210 All-in-One Leaking Ink
the ink collector(well) hav accumulated much ink overtime its due to be serviced.remove the cartridges move the carriage to the middle remove the ink collector pad and clean , clean the collector with methylspirit check for the sensor beside and clean if blocked
Apr 26, 2008 | HP Officejet 7210 All-In-One InkJet...
24 people viewed this question
