Question about Casio FX-115ES Scientific Calculator
How do i change my calculator from fraction answers to decimal when i'm dividing
  • Casio Master
  • 7,993 Answers
If the fraction has just be typed in, press [SHIFT][=] instead of just [=] to get the result displayed as a fraction. However the fraction displayed will be the irreducible form of your fraction (equivalent but reduced to its simplest terms).
If you do not want fractions at all ( input and output)
Press [SHIFT][MODE] and select [2:LineIO]. This is the entry mode of the old generation of calculators.
The other IO mode is MthIO: In this mode fractions are entered as in textbooks, radicals are also entered as in a textbook. If by any chance you like this new IO format but just want the final results displayed as decimal, you can do your calculations in MthIO to get the result. Once displayed the result can be converted into decimal format by pressing the [S<>D] key.
Posted on Aug 27, 2010
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
I have the sharp model EL-W535. When I divide not whole numbers for example 9 divided by 5 they come up as fractions instead of decimals and i can change it from fractions to decimals but it's very time...
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Jan 30, 2011 | Sharp ELW535 Calculator
I ask a dividing question like: 8 divided by 10, and it gives it in a fraction how to I cheange a setting so it gives the answer in a decimal?
If a number is displayed as a fraction or a radical (square root or other roots) you change it into a decimal number by pressing the [S<=>D] key, just above the red [DEL] key.
If you do not care for fractions or radicals, you configure your calculator to display only decimals. To do that you press [SHIFT][MODE][2:LineIO].
Warning: If you do that you will not be able to enter fractions or radicals in the natural (textbook display)
Another way to display a fraction or a radical as a decimal is to press [SHIFT][=] to get the result not the [=] alone.
Hope it helps.
Nov 11, 2009 | Casio FX-115ES Scientific Calculator
Say for instant i wanted to do a promblem 75 divided by 100 = 3/4 i want change answer that is a fraction to a decimal i can the answer clear
75/100 [=] gives 3/4. Press [S<->D] key to convert to decimal 0.75
0.75 [=] gives 0.75 Press [S<->D] key to convert to fraction 3/4
It can convert radicals into decimal and decimals into radicals.
Hope it helps.
Sep 28, 2009 | Casio fx-300ES Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
From fraction to decimal form
yo whatz good playa.. just click Shift, mode, then click 2.
Oct 01, 2008 | Casio FX-115ES Scientific Calculator
Fractions appear when I divide; not decimals
you can also go press the 'mode' button, and go down until you're at 'Exact/Approx' and choose '3: Approximate'
Sep 10, 2008 | Texas Instruments TI-89 Calculator
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Nov 17, 2007 | Texas Instruments TI-89 Calculator
Casio FX-115ES Scientific Calculator Logo
322 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
