Question about Kenmore HE3T Washer
How difficult is it to replace the electrical control board?
    Champion:
  • 245 Answers
Very easy.Just have to find all of the hidden screws and take your time. But it is very easy. Rate me
Posted on Aug 26, 2010
How do I remove the cirucit board on Whirlpool double oven Model RBD305PDS14?
Looks like you have the stainless steel model. It's not too difficult. Once you get behind the oven and can see the control board, it will be held to the back of the keypad with about 4 - 8 screws. Typically it is surrounded by a black plastic shroud. Make sure you take a picture of how everything is plugged in so that you can plug the repaired or replacement board back in. If you are sending your board to a company for repair we suggest you send the shroud with it, and even the keypad as well so they can test it.
Nov 21, 2015 | Whirlpool RBD305PD Electric Double Oven
Why won't door latch lock?
The lock is activated by the control board / timer at specific times to prevent opening of the door (like when the tub is filled with water during the wash cycle and during the high speed spin cycle). The electrical or mechanical part of the lock may have failed or the portion of the control board that energizes the lock may have failed.
If it is just the lock, it may be a relatively easy fix - but it is always possible that the failure of the lock also caused the subsequent failure of the control board too (that's just Murphy's Law) . A control board replacement in these machines typically is not overly difficult job; but you may find the board itself may be a fairly expensive part.
I hope this helps
Mar 31, 2010 | Kenmore Elite 45986 Front Load Washer
I have 1c 1c code what happening ?
Communication problem from touchpad to board. This is difficult to diagnose and usually turns out being the control bad rather than the board. Hope this helps. Either way they are both pretty costly parts. Good luck.
Mar 10, 2010 | Jenn-Air Electric Double Oven
LG LRE30755 Electric kitchen range F-1 fault code
Hello- Control has failed. Replacement boards are available. Need complete model # to chk on part. Not too difficult to replace. Let me know if this info helps and if you need more- Thanks- ED
Mar 03, 2010 | LG LRE30755 Electric Kitchen Range
WE HAVE TO PUSH OUR GREEN PRINT BUTTON WAY TO HARD TO GET IT TO WORK ON OUR PC 920
You will need to remove the front control panel assembly (2 screws and 1 ribbon cable) with copier opened like removing a paper misfeed (or replacing toner unit). Next, you will need to separate circuit board from control panel in order to gain access to the switch under the green print button. Sometimes, you can use electrical contact cleaner (tuner cleaner) to spray into the switch itself, pressing the switch numerous times to evaporate the solution from inside contacts of said switch. Now use a multimeter to check for continuity while depressing the switch and releasing. If cleaning the switch fails, either the switch will need to be replaced or the control circuit board will need to be replaced...replacing the switch isn't difficult, if you know how to solder. Reassembly is reverse of disassembly.
Nov 24, 2009 | Canon PC-920 Black and White Copier
Hi all, i have a samsung le40m86bdx,it has thin red lines on the left hand of the screen on start up. They tend to dissappear after about twenty minutes. They seem to be getting worse slowly and other...
This is typical of electrical problems on the internal circuit boards of HD TVs, specifically with the analog components (resistors and capacitors) or with flaky connections.
The easiest solution is to get a new control board installed by the manufacturer. If it is no longer under warranty, you'll need to check the solder joints on the control board for all the resistor and capacitor connections, potentially replacing defective resistors.... a difficult task unless you've worked on fine-line boards before and have the right tools.
Oct 14, 2009 | Televison & Video
I have a hotpoint range where the oven and clock display suddenly stopped working, but the gas range top does... what do I do?
Sounds like you have a bad main oven control board (ERC).
Bad new is you will need to replace it or have it replaced. Good news is that it is not difficult to do
Dec 20, 2008 | KitchenAid KDRP467KSS Dual Fuel (Electric...
Oasis washer repair
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Oct 08, 2008 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Dometic refrigerator
The system is sealed very difficult to charge. Not to mention expensive. The same price to get a new coil. The boards that control the operations are hard to trouble shoot sometimes. Do you have 12 Volts DC going in to the control board. If yes does the control board inside show green lights that it is working. If so the lower control board on the out side needs to be looked at.
Sep 04, 2008 | Dometic RGE400 Top Freezer Refrigerator
Control Panel
The main control board probably needs to be replaced with an upgrade and the clock display will need to be replaced as well. Depending upon where you are and the cost of service your probably looking at about $700 for parts and labor.
Nov 10, 2007 | Thermador C302U Electric Double Oven
Kenmore HE3T Washer Logo
13 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
