Question about HP Pavilion dv6000z Notebook
Speaker's problem i have HpPavilion, i can hear my laptop's sound through the headphone but not from the speakers
  • mikeprooo Oct 01, 2008
    I have the same sound from speakers whatsoever...but all sounds are fine with headsets or earbuds conncected....tried everything in the audio controls as you instructed the individual earlier....Please help
  • 778 Answers
Unplug the headphones, as having them plugged in usually disables the systems speakers. If you have already done this, then adjust your systems sound volume via the speaker icon in your systray, just to the left of your system clock.
Posted on May 06, 2008
  • Frank  Fernandez
    Frank Fernandez May 07, 2008
    No reply? Thanks for trying?
    I posted a suggestion and you could have given me a reply with some feedback and I could have continued to work with you to hopefully solve this issue for you. That's usually how this works. It takes effort on both of our parts.
Headphones not muting speakers
Are you sure you put it into the right hole I know i have two on my laptop so maybe try that
Jan 10, 2013 | HEWLETT-PACKARD Probook 4530S
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Toshiiba satellite p205 Internal Harmon Kardon Speakers Do Not Work
Most likely its a nardware problem.
If Device manager shows the audio driver is working and enabled and when you plug an headphone into the headphone/audio out and you only get sound from the right headphone then the audio amp chip is faulty.
If the headphone sounds OK then the easiest solution is to connect a set of powered speakers to your laptop.
May 03, 2012 | Harman Kardon HK695 Computer Speakers
Laptop internal speaker not working
Whether you can hear using headphone.if you are hearing sound using headphone means the problem is in the speaker device .if you also not hearing through headphone means check whether driver is installed or not..
Rate it thanks
Mar 03, 2010 | Computers & Internet
Audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Compaq CQ50 Laptop
If the sound works on you headphones the either your built-in  speaker(s)  is/are  bad or more likely the headphone jack itself is broken and not making contact in the speaker position which is fairly common.
Feb 28, 2009 | Compaq Audio card Sound Card
I can not get any sound from my Toshiba Satalite pro M70 laptop.
please check your speakers, try to insert headphones and hear if u can hear any sound, try to install drivers
if u can hear the sound with headphones means there is a problem with ur internal speakers
Nov 24, 2008 | Toshiba Satellite A105 Notebook
Cannot hear sounds through headphones
if you are able to hear normally from the speakers and not from the headphones possible reasons could be:
the audio is muted or very low
there is a mute switch on the headphone that is turned on
the headphone is not firmly plugged in or is in the wrong site eg microphone
hope it helps
please inform if it helps..
Nov 01, 2008 | Acer Aspire 3680 Laptop
Toshiba satellite laptop
I think the problem is in your Headphone jack.
Hope this helps.
Apr 10, 2008 | HP Pavilion dv6000z Notebook
If you can elaborate on the issue, then that would be great!!
Anyhow, let me assist you in this regard.
There will be built-in speakers in all HP notebooks. You can hear Music and songs through them without headphones.
If there is no sound from the Internal speakers, and if you are able to hear sound from the headphones and external speakers, then the Internal speakers gone bad.
If that is the case, then you need to contact HP to replace the speakers under warranty. If not, service center.
If you can reply with the exact issue, then I can explain in better way according to the issue.
Apr 04, 2008 | HP Compaq Presario C500t Notebook
HP Pavilion dv6000z Notebook Logo
61 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
