Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Electrolux Genesis 1572F: 1) One of the two spring/clips/whatever that hold the upright upright for storage has busted. What is the part called? Where might I find a spare? Or should I go to a machine shop? 2) The power cord retainer thingy on the back of the handle grip has broken; any idea about part#, name of part, where to look? (I can't find a manual or whatever, exploded parts diagram, etc., online. I guess this is the planned obsolescence thing--after all, the machine is hardly even 25 years old. Sheesh. bw
LizDahl
  • 75 Answers
SOURCE: Electrolux Oxygen Ultra
The problem is that Electrolux sold a portion of the company to Eureeka, so the Electrolux you are familiar with is under the name Aerus-Electrolux. Aerus vacuums are still produced with the same high quality as always, and still are made in the USA!!!
Posted on Feb 26, 2008
SOURCE: Old vaccum retractable cord
Hello
I have the same Electrolux vacuum, and, I too could not figure out how to open it up.
Here's the site I found:--
http://www.howtomendit.com/answers.php?id=101957
HTH
Uncleclarence
Posted on Jun 03, 2008
SOURCE: Electrolux Lux 7000 retractable power cord
I own an electrolux ambassador III i spent a lot of money on it and if it broke it i would take it to an authorized electrolux repair shop because it sounds easy to fix them but electrolux vacuums have a complicated wire system and it is easy to mix them up or break is worse then it is to begin with.
Posted on Jul 26, 2008
SOURCE: Need source for Electrolux Oxygen parts!
Some parts can be found here: http://www.vacuums24x7.com/elox3ulcocav.html
Unfortunately they don't have the part I need.
Posted on Aug 15, 2008
  • 97 Answers
SOURCE: Electrolux 2-in-1 Pronto is losing suction. We've
yes try new battery it sound like a power problem.thanks
Posted on Nov 30, 2009
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
Clip and spring fell out of wand
Hi Brian,
I'm sorry to hear about this - if the clip and spring have fallen out of the wand assembly, I'd encourage you to give our Helpline a call free on 1-866-693-9766 so we can provide assistance. If it's necessary to replace the wand, this should be covered by our 5-year guarantee, as long as the machine has been used in accordance with the terms and conditions listed in the user guide.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
Jan 02, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The cord won't retract, how do I fix it?
Hold the vacuum at a nearly upright position. Gently tug and release the cord near the vacuum. This should cause the cord to retract. If not, it may be a worn out spring or a broken piece on the cordwinder. If this is the case, it needs to be taken to an Aerus Electrolux store for repairs.
http://www.aerushome.com/storelocator/
Jan 21, 2011 | Electrolux Vacuums
Can't find the belt # for an electrolux genesis upright, serial number u 75344 p
The best place to get a genuine belt is the local Aerus Electrolux store. They're the only place to get a genuine belt without going on line. Most of their uprights use the same belt, so the store should have it on hand. I do highly recommend allowing their technician to make the switch as the power nozzle can be a bit tricky taking apart and reassembling.
To find the store nearest you, follow the instructions on the following site.
Nov 26, 2010 | Electrolux Vacuums
My upright sebox4 will not stand . It keeps on dropping down.
This is usually a matter of lubrication (or lack thereof). If you look under the base of the machine, you will see that the "clip" as you call it is part of the metal axle on which the wheels are mounted. This axle is held in place by 3 metal tabs, each held by a single screw. About mid-way along, there's a spring coiled around the axle. That spring is what holds the "clip" (the bent part of the axle) against the tube that connects to the base of the bag compartment and holds it upright.
It's possible that your spring is broken, but often the problem is that the axle is sticking and the spring can't do its job properly. Try a small drop of oil under each of the 3 metal tabs. If that doesn't work, remove the 3 tabs completely, remove the axle (noting how the spring locates, so you can put it back correctly) and give everything a good clean. Then reassemble and try again.
May 14, 2009 | Sebo X4 Bagged Upright Vacuum
Beater Bar Belt Removal from Upright Electrolux Vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=783793
Generic problem for all Vacuums
Beater bar Belt Removal from Upright Electrolux...
Posted by wrenn on Jul 14, 2008
I am trying to change the belt on an Electrolux Model 1717 Upright Vacuum and I am having difficulty disassembling the vacuum to remove the beater bar and belt.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. . Normally there are screws, clips or levers that would remove the bottom plate or if that does not work then the top cover will come off and that will expose the belt. Once that is off and the belt is exposed then cut off the old belt and then lift up the brushroll on the pulley end and install the new belt around the pulley end and re-install the brushroll. Then use a belt puller or a screwdriver with a bent right or left end to stretch the belt onto the motor pulley and then track the belt in a straight line and reverse you steps in the reinstall of the top cover or bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Vacuums
Feb 10, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux upright vac
Belts can look ok, but after a short period stretch so they won't turn the brush roll under load, if you have never changed it, and if it is a flat belt, I would try a new one.
Dec 26, 2007 | Vacuums
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
260 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
