I have an Konica Minolta Bizhub 501 with a FS-522 finisher that scews the paper when exiting or causes a C-1118 error. We have replaced all parts recommended by the manual. do you have any other solutions for repair?????
marsrover
  • 682 Answers
SOURCE: Konica Minolta Bizhub 7235 copies curling at exit
dear friend:1-check the paper and use fresh paper out of wet and stored in dry place.2-use cooling oil and replce oil cartidge in the heater section.3-replace silicone roller (the lower roller in the heater}4-check for smoth movement of exit section(gears-chain-rubber belt}in a good condition replace any defective part.
Posted on Feb 23, 2008
herminio_hal
  • 210 Answers
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Posted on Jul 09, 2009
  • 1294 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
  • 7 Answers
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
Posted on Aug 22, 2009
  • 51 Answers
SOURCE: konica minolta bizhub
whot is the error code and whot model of bizhub u have???
Posted on Aug 30, 2009
Bizhub 1250 pro
check the setting of the finisher
Jan 14, 2014 | Konica Minolta Office Equipment & Supplies
ERROR CODE C2163
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Sep 23, 2013 | Konica Minolta Konica Bizhub C353 Drum...
Error c1183 on konica minolta
Output trays hit something!!!!!! someone leave a trash can or boxes under the output trays? Will have to remove the rear access to the finisher and reseat the drive motor assy. DO NOT LEAVE ANYTHING UNDER TE TRAYS
Jul 16, 2012 | Konica Minolta Gear 4349163301 for FS-530,...
Konica 7140 gives error code fs516 what is this
FS -516 is the finisher that part of the copier that staples hole punches etc,
Apr 21, 2011 | Konica Minolta Konica-Minolta 4599161...
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Error code C-11C0. Can anybody help?
C11C0 Punch Motor malfunction See FS-501, FS-603 or FS-514 Service Manual.
Feb 25, 2009 | Konica Minolta bizhub C250 All-In-One...
Error code
C11A0
Paper holding drive
failure
• The exit paddle home position sensor (PC6) is not turned ON
even after the set period of time has elapsed after the exit
paddle solenoid (SL2) is activated (beginning of paddle
retraction operation).
OFF even after the set period of time has elapsed after the
exit paddle solenoid (SL2) is activated (beginning of paddle
paper-holding operation).
This will probably need parts as the paddle assembly is likely to be broken.
Nov 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
BH C250 and the Stapler FS-501
Check the 2 covers (one screw on each) where the output elevator tray attaches to the finisher.
Mar 04, 2008 | Konica Minolta bizhub C250 All-In-One...
375 people viewed this question
jasbo
jasbo
