Question about Panasonic Lumix DMC-FZ5 Digital Camera
MESSAGE REMOVE LENS CAP......... LENS CAP IS NOT ON
  • 4,234 Answers
FIrst of all the problem is not with the lens itself but the iris assembly inside the lens. The iris is stuck closed. Lens movement for zoom or focus will have no effect on this. Unless there has been physical damage to the camera, this should be a covered warranty claim. What usually happens is that a small bit of internal lubricant has gotton onto the iris pieces. This will prevent them from moving properly.
Take this camera to a repair shop. This is not a DIY repair.
Dan
Posted on Aug 27, 2010
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Testimonial: "Couldent believe it could be that easy (when you know how to deal with the problem ) a very big thankyou and big thumbs up to the team"
Why do I keep getting the same message to remove lens cap and turn camera off then back on again when the cap is off
Perhaps the sensor is defect? to it is way to dark in the room where you try to take a picture? When the sensor can't give any information to the main board about the light it it receiving, the main board assumes there is a lens cap in front of the lens. It can't think like us and try different codes. On;y the one that goes with the "not enough light" and say remove the lens cap and turn off .....
Jan 29, 2015 | Cameras
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
Aug 27, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
Jul 28, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Mar 11, 2011 | Nikon COOLPIX P90 Digital Camera
Getting lens cap on message push button nothing happens
lens cap means a cap in your camera lens, you have to remove it manually with your hand and not just a push buttons.
May 10, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
When turn on tells me to remove lens cap , no pic
CCD (imaging IC ) went bad and require replacement.
Nov 15, 2009 | JVC GR-D22U Camcorder
Message states Lens CAP is on, when it is NOT.
curious if you ever found out what was wrong. I am having the same problem with my p80. If you can email me your solution. I am thinking of taking it to Ritz. Thanks!
abeaute999@yahoo.com
Mar 28, 2009 | Cameras
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
52 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
