Question about Dryers
I cannot get my dryer to turn on. Is there any fuses or could the timer be bad. I have power going to the switch but nothing turns on. Its a 2000 and the timer # is m460g. Thanks, John
    Champion:
  • 245 Answers
This is called a thermal fuse located beside your fan in the back. Unplug dryer, remove back panel, little white plastic fuse with 2 wires running to it. Cost is about 10.00 bucks. Rate me if I am correct. Good luck!
Posted on Aug 26, 2010
My dryer doesnt go on. The front panel still clicks and when i push start button it buzzes but doesnt go
Belt, fuse, door switch, timer switch, something caught on the drum (all sorts of things get caught back there), heat sensor (depending on the age, had one that had a heat sensor would turn the dryer off, if told the computer dryer was overheating even though had not been running), bad motor, bad motherboard for dryer (again depending on age of dryer)
Jan 06, 2015 | Dryers
My estate gas dryer isn't working, i hear timer, but motor not turning
Door switch, broken belt maybe. The way it works if the fuse on back is ok and their are no obstructions which might cause a fire, the motor must be turning in order for the centrifugal switch inside it to allow power to the gas assembly. If that same fuse was blown however no power would get to the gas assembly but the dryer will still run. Based on that I would say you have a bad door switch. if not that then it is down to a bad motor or a bad timer. In the case of the timer it is a strong possibility the knob could be broken or the stem inside the timer itself is not advancing the cam and therefore the machine will not start. I saw that one just last week. Them timers are crappy on them machines.
May 22, 2013 | Dryers
Electric dryer wont start. Door switch turns light on/off. Timer is heard ticking. Press start... nothing. Tried bypassing all parts in the back.. Thermostat, thermal fuse... still nothing. Could it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 27, 2011 | Kenmore 62602 Electric Dryer
Won't start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 29, 2009 | Kenmore 64902 Electric Dryer
Dryer Won't Start
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer will not turn on.
May 26, 2009 | Whirlpool LER5636P Electric Dryer
Dryer want come on when you set timer
could be thermal fuse or bad start switch
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
G.e. Profile gas dryer, wont turn on but has power
Some GE dryers use a non-resettable thermal fuse. It is a dime sized object with two wires attached on the top of the element housing. (Unplug dryer, take screws out or push in clips holding dryer top down at the front of the dryer top, swing top back, see thermal fuse near very back) Newer dryers use an automatic resetting thermal fuse. The replacement part for either will be the same auto resetting one. Your problem could be several other spots, however. Check for 240 volts at dryer. (not just 120) When you swing that top up, make sure the belt is there going around the drum. (if belt broke, it switches off power on most dryers) Could be a door switch, internal motor switch, timer contacts, bad start switch, burnt off / broken wire, maybe just a stripped over start knob.
If you find that the thermal fuse was the problem, you still should clean out the vent and eliminate all or as much flex duct as possible to prevent the thermal fuse from tripping again.
Nov 29, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
Dryers Logo
219 people viewed this question
Top Dryers Experts
