I plug V55 in and it works fine and once i pull the plug out the red battery symbol starts blinking and eventually the screen goes blank, within 1 minute. While the machine is off and plugged in, the two indicators on the left, one for power and one for the battery are both bright green. Thanks for you help.
  • 11,800 Answers
The battery has aged and is no longer capabler of holding a charge. Replace it.
Posted on Aug 26, 2010
No picture no sound. Red led blinks once relay clicks once and repeats
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 25, 2014 | Sony KV-XF34M65 34" TV
My 7 inch irulu tablet does not charge
Try a different charger that is capable with your device, check battery, or reset if you can. Luck to you
Jan 04, 2013 | Tablets & eReaders
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Syncmaster 2232gw led blinking.
Change the screen resolution. The video card or video display may not be compatible to the supported video setting of the monitor. Try changing the video resolution to a lower setting such as 1024x768 and bit depth to 32 bit.
Mar 15, 2009 | Computers & Internet
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Power Up Problems
7 blink error is 8.6 volt error on that model. usually tied to y sustain board located on left side of set looking from back. disconnect y main from power supply and power on and if comes on verify power supply primary voltages located on label on pdp itself. if voltages present you would need to replace that board as not designed for component level repair. however if you find failed components like swollen caps or burnt ic's you could replace those. also when replacing the y main board there are two y buffer boards to left of main board that also would be recommended to be replaced at same time as they work as circuit and replacing one board without other could cause failure to other boards still in set
Aug 13, 2008 | Philips 42PF9431D/37 TV
Power Up Problem
You have a 8.6v supply error according to the 7 error code being displayed, what you can try is when the set goes to blinking disconnect the Y sustain board (if looking at the tv from the back the board on the left) from the upper left side of the power supply, if the error code stops then you know your Y sustain board is pulling down your power supply and causing the error, if the error code continues you have a probelm with your Logic Board (located under your Small Signal Board) disconnect this from the Y sustain board and see if the error code stops if it does you know that the Logic board is bad, if the error code is still blinking then the 8.6v supply line from the Power supply is faulty and the Power Supply needs to be replaced
Blackberry will not turn on, I just get a red light
this happened with my first blackberry and it never turned back on guess what softwar glitch it was never goig to work again so i got a new one the second one started having issues within a month and eventually got to the point where i couldnt wifi it would turn off on me for no reason tell me i had no service when i should have hang up on people freeze and simply sucked took it in to get it fixed guess what another software glitch that one went to blackberry heaven and i got another one this one is only 1 month old has all updated software and hey guess what no issues at all i suppose every phone has bugs in it to begin with look the aple iphone blew up when it first came out until they fixed the issues with it.
if your on a plan ur under warranty with blackberry take it back and there policy basically replaces the phone.
good luck
Jul 30, 2008 | RIM BlackBerry Pearl 8100
Screen goes blank when I plug camera into computer
I have to say Mac's I know nothing about. But the simple way would be to purchase a universal USB card reader- and use that.
Jul 04, 2007 | Canon PowerShot A520 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
