Question about Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
Only power on for 10 seconds and shuts off - Sylvania SRPD442 42 in. EDTV-Ready Plasma Television
  • 4,234 Answers
A bad capacitor is a possibility, but lets define the problem first.
The set is shutting down because a problem is detected. This is commonly known as "protect" mode. With plasma sets, there are many reasons for this to happen. There are effectively at least 2 stages of power supply inside these sets. 1) The standard power supply that drives the video processing etc and 2) the plasma suplpy. A fault in either supply stage can cause this problem. I would not suggest just changing capacitors without an understanding of the function of that part. The cap may have been damaged as the result of another part failure. Just changing the cap without furthrer investigation can lead to more problems. This may not always be the case, but it can happen. At the very least, I would suggest that you invest in a detailed repair estimate from an authorized service center. At least that way you can have some cinfidense that the repair will be correct and long lasting.
Dan
Posted on Aug 26, 2010
  • Sylvania Master
  • 3,866 Answers
Let me break this down, The tv powers up for 10 seconds the shuts off. This issue would be in the power supply board now let me break down the possiable causes not you got to be aware I am not there I never seen your tv ext ext.
1. Bad eletrolytic capacitor"
*This is caused by stress,heat,dust,and the list goes on. what happends is the eletrlytic capacitor basically swells up or leaks causeing it to fill and the drain real quick "cutting off the flow of eletricty to the rest of the tv ultmatly shutting it down"
A capacitor looks like this only power on for 10 seconds and shuts off - fd12474.jpg
These capcitors cost $2.00 with a soldering iron , solder removal and some tools you can extract these and put in new ones. WARNING: It may contain voltage left over so if you do not know what your doing by all means leave it to the tv repair guy. I do not want Fixya on the 11 o clock news, or my **** in court explaining why I told a novice to extract one of these. You can get a jolt it can cause injury up including your death. So with that in mind if you do not know do not touch.
With all the warning aside now that you understand the dangerious voltages you basically extract the old and put in the new.
DO NOT SHOOT THE MESSENGER
Please be safe. There are plenty of youtube videos on how end users saved thousands of bucks on TV repair.
Have a nice day It would be considerate if you left a rating and feedback before you go. Many thanks for using fixya.com
My new hannspree 10'1 tablet has completely frozen after 10 mins of watching bbc i player the screen froze and does not respond to anything at all it wont even shut down im
Press and hold the power button for @ 10 seconds. That should shut down your device. Then, after it shuts down, again press and hold the power button until it reboots.
Jan 04, 2014 | Audio Players & Recorders
Lion OS; can't shut down, Neo Office blocks quit command on MacBook
Hi Marvin.press the power button for about 10 seconds and the mac will shut down. Make sure it's 10 seconds and not 3 seconds.
Jan 03, 2012 | Apple Tacoma Computers & Internet
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
Tv will not power up, shuts off after 10 second
http://serviceman.site88.net/index_files/MitsubishiTV.htm
Oct 01, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Power issue
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Jul 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
New system build, shuts off after 10 seconds
If you have had this problem sence the system was built and your power supply is less then 400 Watts. You will need a 400 Watt power supply or higher. Check the specs for our motherboard.
Dec 05, 2007 | ASUS P5N-E SLI Motherboard
Player shutting down after 10 seconds
Shutting down completely like power is gone or just DVD stopping with power on? If completely shutting down the look in power supply and find bad capacitor and replace. If DVD stops with power then look at laser, clean or maybe damaged.
Sep 14, 2007 | Polaroid PDV-1002A Portable DVD Player
Sylvania SRPD442 42 in. EDTV-Ready Plasma Television Logo
37 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
