Question about Mach Speed Matrix PM9MS Motherboard
Blown or Poofed CAPS next to processor. PC will not load WinXP...get an IRQ_LESS... Worth replacing CAPS? Or get another MOBO, if so, where? Thanks
  • Mach Speed Master
  • 4,806 Answers
Replacing the caps is totally up to you depending on whether you like the motherboard and want to keep it. You can pick up replacement caps for next to nothing and they are fairly easy to solder in.
If you want a new or second hand motherboard then you should be able to pick on up from a reputable computer store, eBay or a repair store.
Regards.
Posted on Aug 26, 2010
I have OptiPlex SX280, processor runs at 100 % for few minutes and the PC reboots. I have cleaned the fans in the case? What could be causing the PC to reboot.
Hi Jerrvk, These Dell SX280's are plagued with bad capacitors, Afewtr about 4 or five years of use the capacitors star6t5 budging and leaking electrolytic acid, The only fix is to hace the Caps replaced on the motherboard. We jsu got a whole load of these last week and are replacing the caps on the ones that are fixable. If you know someone that works on electronic this fix is really inexpencive. The Caps cost between $.60 to $1.50 each. Find someone that know how to solder real good, Have them inspect your motherboard, They will see the caps that are buldging on top. The ones under the hard drive are usally the ones that go first. Good Luck and let us know how you make out. pc_techserv
Aug 11, 2010 | Dell OptiPlex SX280 PC Desktop
Machine doesn't power up
Remove and reseat all memory, power and processor.
Check your power supply and if good check the board for bad Caps.
Sep 20, 2009 | Abit KV-85 Motherboard
Turned off PC one night working fine. Next time try to use, PC wont boot. No video display, no bios, no posts, nothing. Gateway Desktop GT 5464 w/ integrated video, Intel E2140 Processor, Intel 945GC Mobo....
Have you tried booting it from yor CD drive with bootable software?
Any led flashing anywhere in the computer?
If not, we are talking about energy problem. Try fitting the energy cord firmly, try connecting the battery charger in a different power outlet.
Aug 26, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Foxconn MoBo 947p7aa & keyboard lockup
Check if the processor temperature. ... sounds like that could be the problem. It would cause the computer to FREEZE the moment you start "working" on it because then the processor must do it's thing but it instantly overheats because either the processor cooler fan is'nt functioning correctly or the thermal paste has hardened and no longer offers a "connection" between the processor and the fan
Jul 06, 2009 | Foxconn (865G7MC-ES) Motherboard
3870x2 GPU issue
I read your other comment posted on the other topic, and yes I have to agree, I think your GPU has blown.
I write this, because I had the same problem about a year ago. The power switch on my old tower case had broken, so I bought a new one. Swapped everything over, turned it on, and, wham! Everytime I tried to boot, I got either the Blue Screen Of Death, or nothing. I tried everything. I swapped my GPU, as I had a spare one, but the still nothing. So I thought I had blown Mobo. Bought a new one, but still the same. In the end I gave up and paid for an egineer to have a look.
Basically, when I swapped cases, I blew the Mobo (and I'm a systems builder, lol), this in-turn blew my GPU (which is why it didn't work on new Mobo). I replaced GPU on new board, and would you believe it, it worked.
Replace your GPU (but if you can, test with a spare one, just in case it's your Mobo that's blown).
Cost me a bomb, but I hope my mistake saves you money.
Tim
Dec 09, 2008 | Computers & Internet
Computer shuts off
go to the bios then check, your processor deatials
Oct 24, 2008 | Computers & Internet
Windows won't boot is it the otherboard?
1) It can be the mother board ( check for blown caps or a missing heat sink on the main chip if the heat sink is missing you can replace it. If blown caps replace the mother board. Capacitors are little cylynder shaped things on the morher board the tops should all be flat if they are pooched any they are blown)
2) it can be the processor make sure the heat sink is on it and the fan is turning. MAlke sure you don't have it over clocked and if the processor has been removed that they put heatsink paste back on it.
3) a power supply going out or over loaded can cause this problem as well.
May 15, 2008 | Acer Aspire 5100 Notebook
Acer aspire t135 desktop doesnt start
Howdy...
I would shed the loads and measure the power supply (pinouts available everywhere on net) what that means is disconnect the drives and I/O cables to them (at the MOBO). Remove any recently added cards or ram . You should be able to see video and/or beeps if voltages are reasonable . A spare power supply would be handy .
Slowly add things until failure shows or if MOBO seems at fault ,try your stuff in another PC . There has been rash of swollen/leaking caps 'round these parts due to bad power supplies or bad caps . Bad power supplies can destroy the MOBO . Changing these caps will often resurect a MOBO
but this is not for the inexperienced desolderer as these
boards are multilayer .
Good luck
Hugh I
Jan 31, 2008 | Acer Aspire T135 PC Desktop
Motherbooard for Compaq Presario sr1050nx
A7 indicates that it is a K7 series - a socket 462. Socket 7's were for the old Pentium 1's and AMD K5, and K6 I,II, and III series of pre-athalon processors. Socket 7 was also the last socket to see Cyrix chips.
Oct 15, 2006 | Compaq Presario SR1050NX (DW257A) PC...
Mach Speed Matrix PM9MS Motherboard Logo
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Gareth Cockram
Gareth Cockram
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
