Question about Magic Chef MCBR440 Compact Refrigerator
My Magic chef compact stopped cooling overnight. what can i check?
    Champion:
  • 245 Answers
Sounds like a freon leak or your compressor is bad. Sorry.
Posted on Aug 26, 2010
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef Refrigerator has stopped cooling adequately.
Check the compressor and the Relay, the relay is located on the compressor itself. you should have full voltage to both of those. If oyu have voltage to the relay and not the compressor then the relay is bad. If you have power to both and the compressor will not kick on then you have a bad compressor and it is best to just replace the fridge
Apr 26, 2009 | Magic Chef MCBR170 Compact Refrigerator
Unit stopped cooling. Measured circuit resistance L1 to L2, approx 10 ohms. Plugged unit in, heard a click in a few seconds. Unplugged and measured circuit resistance which indicated circuit open. ...
You'll need a 3-1 start kit. The clicking is those starting components. We shipped one out yesterday for 35.00 and that included overnight Sat. delivery the part alones was 20.00 with instructions. Very easy and the replacement kit is better than the original parts and available at most any appliance parts store. Good luck.
Aug 20, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Magic chef compact refrigerater stopped cooling compreser is warm to touch and is makeing clicking noise every few minutes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | Magic Chef MCBR445B2 (4.4 cu. ft.) Compact...
It is making a tic toc noise. It is not refrigerating. The model is : Magic Chef MCBR445W1 Thanks
the noise is from the ptc overload relay located in the lower rear on the compressor,its a safety component that aids in starting the compressor and shuts it down if the compressor overheats,unplug it off the compressor and get an exact replacement and the unit will again cool and stop tick-tocking
Mar 03, 2011 | Magic Chef MCBR445W1 Compact Refrigerator
My magic chef mcbr445s will not cool down the compressor NSA30la cg stays hot what should i change out
check the condenser fan if working good or clean you condenser unit use water from faucet
Feb 24, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Refrigerator stopped working
check if the in side light works and if it does then it is your thermostat.allso check the power supply to your frige
Apr 19, 2009 | Magic Chef MCBR440 Compact Refrigerator
Not cooling
From my earlier post, our compact Magic Chef 'frig was not running at all.  It still looks perfect, so decided to check on the repair.  It turned out to be the "starter switch," I think is what the switch was called.  The repairman said this is a very common problem, so he had the switch we needed in his truck.  It was repaired quickly and is running great.
Cost was about $140, part plus labor.  A replacement would have been only a few dollars more, but would take more time and effort.  FYI, the compressor on these Magic Chef refrigerators has a 5-yr warranty.
Hope that helps someone. Jaci
Mar 01, 2009 | Magic Chef MCBR440 Compact Refrigerator
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCBR440 Compact Refrigerator Logo
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
