Question about Sony Playstation 3 (PS3) Console
My ps3 console start up but on the screen i cant see anything. I have my console conected to the tv via HDMI cable and i dont know if is that the tv does not recognize the output but the same trouble happens with the rca cable. This problem happens frecuently and last some days and sometimes weeks and later the console start working well. I apreciate your help, have a nice day!! (Sorry for my english, my language its spanish) El problema que tengo es que cuando enciendo la consola, no veo nada en el monitor del televisor y el televisor dice que no detecta ninguna senal, tengo la consola conectada con un cable HDMI e intente con el cable de RCA y lo mismo sucede. Este problema sucede frecuentemente por varios dias o semanas y luego vuelve a funcionar normalmente. Le agradezco su ayuda!!
  • 27 Answers
Give this a try it might help CLICK
Posted on Aug 27, 2010
Why will my ps3 not workwhen conected via multi-av cable to the RCA jacks?it does work conected to a hd tv via hdmi
When you use an HDMI cable with your PS3, the system is outputting the signal in a digital format. You need to tell it to switch back to displaying in an analog format to use the RCA jacks, otherwise it won't work. To do this, turn off your PS3. Then, once it's off, press and hold down the power button on the system. After a few seconds, it will beep and reset the output signal back to analog. Just make sure only your RCA cables are plugged in when you do this. Hope this helps!
Aug 26, 2011 | Sony Playstation 3 (PS3) Console
I switched my ps3 to a new tv and cant get it to work. I reset it to rest the video feed but it still will not bring up anything. i is like nothing is connecte to the tv. i have checked and rechecked the...
If ur ps3 console wont start up....then the things to check are>>> 1.check ur power cable 2.check whether u have inserted the disc properly and precisely. 3.check the insertion of memory card... 4.check the video port.......
click here to download ps3 repair guide
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
I have the same problem with my Samsung LE46A656 A1F Full HD
If it was doing it on your old console then its the TV not the PS3.
Causes: HDMI cable (Replace cable), HDMI socket on TV (Get it repaired), If it happens on all HDMI inputs then the video board maybe faulty, Interference - location of PS3 to other equipment.
The first thing to do is move everything else away from your TV except for the PS3, now factory reset the Samsung TV and make sure your firmware is up to date my records show that an update came out in May for your TV, also factory reset the PS3 and setup the HDMI video settings using the wizrad in the PS3, now connect the PS3 through all HDMI inputs to see if its one input or all, if all inputs are the same then the TV maybe faulty.
Let me know how you get on.
Thanks
Sep 05, 2009 | Sony Playstation 3 (PS3) Console
I have a ps3 i play my ps3 on my normal television then i put it on an lcd flat screen tv i conected a hdmi cable to my ps3 because i conected put it on an lcd tv. then i put it back on my normal tv but...
ok to reset the video and audio port back to the av port for a normal tv when the ps3 is off hould down the on button unit it beeps 2x fast then it will got back to original setting
if u put in hdmi it will take over the av port so u have to chanage it back to it via ps3 settings or the reset option
hope that helped
Jun 14, 2009 | Sony PlayStation® 3 (80GB) Console
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to hd tv
ok here's what you do. Hook up your ps3 to your hd via hdmi cable then turn the tv on first. Then turn the power on to your ps3 and switch tv to hdmi. wait a while then a screen should come up and you should see and screen where it says an hdmi device is connected do u want to accept theses settings say yes. sometimes the "handshake" doesn't happen properly. If u already know this or have tried this it could be that your tv needs a firmware update, happened to me.
Jan 12, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Cant connect via hdmi
Put it in standby (Red light) and with the HDMI cable conected, press and keep pressed the on/off button in the console for about 5 seconds.
I hope that helps..
Let me know if that solve it..
Computerrep
Dec 23, 2008 | Sony Playstation 3 (PS3) Console
Black screen on ps3
What tv you have and how you sony is conected with tv via hdmi,scart or video out
Jun 26, 2008 | Sony Playstation 3 (PS3) Console
Hdmi
Which TV do you have? Hopefully then we can help. :)
Sep 01, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
