Question about Refrigerators
I have a crosley conservator refrigerator, it says "twist air" on the bottom of the freezer door, and while the freezer works ok, the fan in the back of the freezer has seemed to have stopped working, like 3 days ago, and the refrigerator area wont' cool any longer. Of course, I opened the freezer door and pushed the button to see if the fan would come on, and it would not. So, the first thing I did, even though there was really no ice build-up at all, was to completely turn it off and defrost it, and clean it, and then let it sit for 24 hours. I thought the fridge part might start working again, but alas, it will not. Is there a power supply or something that I can replace myself, so it wont cost me an arm and a left to fix it? We've had it at least 7 years, so there isn't any warranty left, and I would hate to throw it away since it's in mint condition otherwise. Can anyone help me figure this out? And if you are wondering the model number, I never found it, I looked everywhere. It's a shorter model and is only 63.5 inches tall and 23 inches wide, if that helps you know the approximate model.
  • roberthoyt Aug 30, 2010
    Would this be called the "evaporator fan assembly", when I ask for it as a part? Would it possibly be bad, even if you can turn it by hand from inside the freezer?
    Champion:
  • 245 Answers
Replace the evaporator fan in the freezer.
Posted on Aug 26, 2010
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ET20GK top freezer works ok bottom refrigerator does not cool. I defrosted, the two air passages from top to bottom are open. The fan in the freezer is running .Is there another fan? I vacuumed...
make sure you air damper in the refer section is open
and allowing cold air from the freezer in to refer section, close the freezer door and make sure you can feel the cold air dumping in
its good thaty you cleared the two air passages
but something may be clogging your air diffuser
Oct 26, 2009 | Refrigerators
Refrigerator doesn't work but freezer does double door stainless steel bottom freezer bought in 2006
Check the air circulation fan motor for proper operation. It's located in the freezer compartment. If it doesn't work, replace it. If it's ok, check your door seals for gaps and leaks. Also check for proper door closure and alignment.
Jul 31, 2009 | Refrigerators
Maytag mff2557hew fridge not cooling. Freezer ok.
Sounds like the Freezer Fan is wearing out or is worn out. This fan problem is very hard to detect. The reason is that when the motor is starting to wear out the fan will spin, but at a much lower rpm. This is enough to keep the freezer cold. but will not ciculate enough air thru the freezer and the refrigerator to prevent freezer from and refrigerator from cooler. The cost to repair/replace this fan is a minimum of $300.00
Jul 27, 2009 | Maytag MBB2256G Bottom Freezer...
Refrigerator wont stay cold.Freezer works fine,no frost buildup
i replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 27, 2009 | Crosley CRFF16 15.9 Cu. Ft. Frost-Free...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Kenmore 5355
There is a fan inside the freezer which circulates cold air through the air diffuser and then through the return duct at the bottom of the fridge. This fan may not be working. You should be able to hear it when you open the freezer door. If you cannot hear the fan going with the door open, keep the door open and press the button that switches the internal light off. The fan should run. If no fan running in freezer test for supply to fan. The fan may be faulty or the thermostat which is in line with the fan could be faulty.
Oct 29, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerator
Sani, see if the evaporator fan is running. That would be the fan in the freezer compartment. It moves the cold air to the bottom. If that is ok, then you may have a defrost problem. Is the freezer panel in back all frosted over? If so, it's probabley a defrost issue. Check these things first and post back...Catriver.
Mar 12, 2007 | Whirlpool GAFZ21 Bottom Freezer...
Refrigerators Logo
302 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
