Question about Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman DLT 2000, model 917.272243. Will run okay on flat ground, but will not go up a hill. Belts are all okay, and new. Unable to locate any hydrostatic pedal range adjustment. Hydrostatic pump going bad?? Looked entire unit over, but find no problems.
5 Suggested Answers
  • 95 Answers
SOURCE: Craftsman 15.5 hp 42
It takes 15w-50 or 20w-50 synthetic motor oil.Do not use hydrostatic fluid, it is too thin. Amsoil, Mobil-1, Purple Power or Lucas are four of the most popular brands. You have to suction it out from the plug on top of the transaxle and refill it there also to within 1.5 inch from the top,do not overfill,air is needed in top for expansion.
Posted on Aug 15, 2009
Testimonial: "hey please call my cell(828) 413-7222 need help now its worse"
  • 4 Answers
SOURCE: Hydrostatic drive is weak
Try pulling back on the left foot pedal. This manually adjusts the drive belt tension and is a sign that the engine pulley has worn to the point the belt looses traction. A local repairman told me this last week and mine works fine now although in the very near future I'll need to replace the pully. Good luck
Posted on Sep 17, 2009
  • 420 Answers
SOURCE: john deere 300 garden tractor hydrostatic drive will not work
check two things, make sure the by-pass rod is pushed all the way in and the drive belt from the engine to the rear end (tranaxle). If both check out ok do not attempt to service the tranaxle at home. have thet serviced by a dealer.
Posted on Jun 02, 2010
  • 420 Answers
SOURCE: my craftsman hydrostatic transmission dont want to go up hills
This symptom is cause most often by the following.
Worn and slipping drive belt which is separate from the blade/deck drive belt.(replace the belt).
by-pass lever (rod) not fully engaged (push it all the way in)
travel pedal or linkage is faulty or out of adjustment ( take to dealer)
Transaxle is faulty (take to dealer)
Posted on Jul 19, 2010
Model 944.601380 Wouldn't pull up even a small hill. How thick should the rubber on the friction disc be? It doesn't seem worn but that is all that I can see drives the wheels. Can't find any belts to...
If it is a Craftsman riding mower, it has to have a drive belt unless it is shaft-driven. Its behaving precisely like a mower which has a drive belt that is so worn its "hanging by a thread - literally". That's why it won't pull a hill but is OK on level ground. You need to replace the drive belt, but you need to find it first. Consult your manual about what belt to use (you can get it at Sears) and the routing pattern.
May 24, 2016 | Craftsman Garden
DLT 3000 25 OHV belt keeps breaking
In this parts diagram notice idler pulley #145. Its the spring loaded moveable puller. Make sure that it's mounting is tight and and that it runs true. If the pulleys don't stay in alignment it will cause trouble.
http://c.searspartsdirect.com/lis_png/PLDM/P0412015-00010.png
CRAFTSMAN Lawn Tractor Parts Model 917275820
Check out youtube for help videos.
mower deck belts breaking YouTube
Oct 04, 2014 | Garden
Wiring diagram for Craftsman DLT 2000 model number 912.272280
go to craftsman parts and type in 917.272280 instead of 912.272280 and download the manual... they have live chat on their website that'll help you
Oct 04, 2013 | Garden
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need to locate the safety switch on a craftsman dlt 2000 lawn mower
witch switch do you need the one near the brake/clutch pedal the one on the seat the one on the the one on the trans for mower deck reverse cut out?
Jul 13, 2012 | Craftsman Garden
Brand new less than 30min on tractor when mowing down hill white smoke bellows out the exaust I imediatly shut mower down and am parinoid about restarting for fear of damaging motor.
how steep of a hill was it?steep enough for oil to go forward into the from of the engine roll it to a flat surface and check the oil level if ok run the engine and let it burn off if the hill ii's that steep then stop using it on the hill check the manual for running angles
Jul 10, 2012 | Craftsman GT 5000 26 HP54" Garden Tractor...
Routing Of Deck Belt For DLT 2000 48 inch Deck
It can be found on amazon, here... take a look Amazon com DLT 2000 belt. I hope this was helpful. Have a nice day
Nov 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Runs fine on flat ground will not pull a hill
Sounds like you could be running on one cylinder. I assume you have a two cylinder B&S, Tecumseh, or Kawasaki. Remove one spark plug at a time and try driving the mower. If you have nothing on one spark plug and drives exactly the same with the other, then you have a dead cylinder. Can be a spark problem, unlikely a fuel problem assuming a single carb, a bad head gasket, bent push rods. A lot of B&S Vanguard engines, including mine, have a tendency towards bent push rods.
Oct 18, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
356 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
