Question about Solo "" Sprayer Nozzle Kit (0610408 P) 0610408 P
Need a solo #456 sprayer nozle p;art - Solo "" Sprayer Nozzle Kit (0610408 P) 0610408 P
I have a solo456 but i need a new lance handle can you help
Posted on Mar 25, 2011
Washer fluid wont work
Start with basics. check if resevoir is empty. most likely a frozen nozle. Maybe a frozen, blocked or kinked/broken hose. If you are in cold area, warm up car in garage add washer fluid with low freeze temperture. If not froze; look up diagrams online and check hose, filter screen in resevoir, and tip of nozle.
Dec 13, 2013 | 2003 Mercury Mountaineer
Kohler sprayer with forte single handle, will not spray well. When sprayer is on the flow to faucet cuts off but there is only a small amount of water coming out the sprayer.
Check to be sure the hose isn't kinked somewhere below the faucet. If there aren't any kinks there is likely debris stuck behind the nozle screen, remove it and clean it- or your handle mechanism is broken. Replacement handles and hoses are fairly inexpensive if you need one they're easy to find at most big hardware stores or on Amazon
Sep 05, 2013 | Kohler Kitchen Faucets. Forte 1-Handle...
How to remove pressure cylinder
I have a solo sprayer 465 looking for parts for can not find any repair parts.
Sep 04, 2013 | Solo Garden
My solo backpack sprayer won't pump up when I use the handle. What's wrong and how to repair it?
chabunga offered really good info...except for the suggestion to use Vaseline on the 'O' ring. NEVER use Vaseline on anything rubber, because it is a petroleum based product and it will cause the ring to deteriorate. Use a non-petroleum based lubricant instead.
Jun 03, 2012 | Solo Backpack Sprayer
I have a SOLO 461 sprayer. After months of good service, the pressure from the spray jet drops after a few seconds of spraying. If I close the trigger, then re-open it, the spray again lasts just a few...
if it is a diaphram style replace diaphram if it is a piston style replace piston how to's are easy on both just take ur time and pay attention to removal process
Jan 15, 2011 | Solo Sprayer Parts Shutoff Valve Assembly
I have a 3 gal. back sprayer. When you try to presureize the tank to spray, The pump seems to work but there is no pressure. If repairs are necessary, where in the Redding, Ca. area is a repair shop for...
Hi there
There are many possible reasons for your sprayer not pressurizing. If the pump lever is moving freely and does not seem to be building pressure while pumping it is possible that the O-ring at the valve is damaged, the seal in the pressure regulator is leaking, the piston or the collar is worn. Any of these problems will require disassembly of the unit and inspection of each part. If you do feel resistance building as you pump but quickly loose pressure you likely have leaks in the diaphram, it's seal, the pressure cylinder or the tank itself.
If you are comfortable disassembling the unit and inspecting the parts for wear or damage most of the individual replacement parts are fairly easy to replace and readily available online from Solo or at many retail outlets and supply companies. Solo has done a great job with how-to videos and instructions for each procedure on their web site www.solousa.com
If you are not comfortable disassembling and repairing your sprayer yourself you can try contacting a mower/equipment repair shop in the Redding area as is seems the nearest Authorized Solo sprayer repair center is Cloverdale Saw in Cloverdale CA, 707-894-2273
Dec 31, 2010 | Solo Backpack Sprayer 3 Gallon Capacity,...
I have lots of pressure in the tank but not much is coming out. I need a picture of what to clean please. Gerry
Try taking apart your trigger and tip and cleaning them. Then try again see what happens.
Aug 20, 2010 | Solo Backpack Sprayer 5 Gallon
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
I have two 428 solo back pack sprayers both of the pumps have crackes in them where do I get parts. Help!!!
i have 428 with a broken pump handle. the solo co. has some parts.their ph. no. is 757-245-4228,i talked to a young man @ ext.352,name is shawnatin.if you can't get the parts,i would like to offer you $5.00 a peice for the handles & shipping cost.just snapped today while working in my yard.
May 02, 2009 | Solo Backpack Sprayer 5 Gallon, Model# 428
Solo 425 and 475 spray packs.
I have a 425 that I have had to remove the pressure cylinder. I found this on the internet one time, but can't find it again. Anyhow, this is how to remove the pressure cylinder on a Solo 425. Do all the disassembly instructions in the owners manual. Then get a short 2x4 or 2x2 and place it on top on the pressure cylinder through the opening on top of the tank. Then give it a good whack with a hammer. Don't be shy, that ****** is in there. It may take more than one whack. Once you have the cylinder out there is a screen on the cylinder that must be cleaned. To re-assemble, turn the sprayer upside down, insert the pressure cylinder, lay the 2x4 across the bottom of the cylinder and use even force (and hammer) to force the cylinder back in. Stop when you get to the O ring seat and you can do the rest by hand, being careful not to pinch the O ring. I have had Solo sprayers for many years and think they are great. But when it seems that when I leave glyphosate (Roundup) in the sprayer it clogs the screen. My hard water may contribute to the problem.
Mar 27, 2009 | Solo Backpack Sprayer
Solo "" Sprayer Nozzle Kit (0610408 P) 0610408 P Logo
63 people viewed this question
Top Solo Garden Experts
Colin Stickland
Colin Stickland
Steve
Steve
Level 1 Expert
Are you a Solo Garden Expert? Answer questions, earn points and help others
