Question about Sewing Machines
I have a janome DC4030 and am having problems with the automatic buttonhole feature. It does the first 'leg' of the buttonhole fine but the stitches on the final 'leg' are uneven and at times so long they touch the stitches on the first leg making it impossible to open the buttonhole without ripping the stitches! I have tried changing the stitch length and width but this has not solved the problem. This is a 'new' problem. I am using the same fabric, threads and interfacing that I have always used. Please help!
Trifect7
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
  • 323 Answers
SOURCE: Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Posted on Jul 15, 2008
  • 16 Answers
SOURCE: Brother Super Galaxie 2100 Buttonhole lever not working
I have a problem with my CS 8150 which sometimes tells me to lower the pressure foot even though I had already did it. What clears the problem for me is that I eject the thread cassette and re-install and I can go ahead and sew. Try that to see if it will quit telling you to pull down the lever.
Posted on Sep 15, 2008
talk2ginny
  • 34 Answers
SOURCE: buttonhole on second side was only half the length of first side
Hi, did you buy the machine from a dealer - if so, I would take it back and ask them to show you how to do buttonholes again. It is also possible that, although the test buttonholes sewed out correctly, the automatic button sensor needs professional adjustment.
Before going back to the dealer, find the section in your manual that discusses buttonholes and read thru it very carefully. Pfaff machines are not intuitive, and the manual might describe a way to adjust the automatic buttonhole settings so they sew out correctly.
If you need more help, please repost and I'll try to help or put you in touch with a dealer who can help
Good luck, Ginny
Good luck, Ginny
Posted on Jan 31, 2009
Hi clever people! I've been trying to do a button hole on my janome j3-24 which is meant to be a 1 step button holer. However, so far every time it does it fine round the 2 small sides and the first long...
This is a sewing machine we don't have in the US, so I'm guessing here, but I think the stitch pattern is unbalanced. On some machines, there's a dial to "balance the patterns", which you can turn to restore symmetry to something like a buttonhole. Often you need to automatically stitch out a pattern in order to reset the balance knob.
If your machine doesn't have such a knob, it's time to take it in for a lookover.
May 24, 2014 | Janome Sewing Machines
Finding equivalent
I can't seem to find a decent picture of the Kenmore 385.16120200, but from the replacement parts that I can see, it may be close to this one:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/2212
Or maybe:
http://content.janome.com/index.cfm/Machines/Sewing-Quilting/Magnolia_7318
Janome is an excellent brand, and any Kenmore built by Janome is going to be just as good, but a little less expensive. However as the Kenmore sewing machine line seems to be hard to find even used, and if you are considering buying a Janome, I would highly recommend a few features to you:
Drop-in Bobbin, One-step Buttonhole, Automatic Needle Threader, and maybe (depending on your tastes and preferences) a few electronic features like Needle Up-down and Push Button Stitch Selection. If at all possible, go into a shop and try before you buy. Hope you find what you are looking for!
May 04, 2014 | Kenmore Sewing Machines
Cant get my janome excel mw 3018 to do an automatic buttonhole
I would suggest taking the machine back to where you bought it & letting them show you how to make a buttonhole or getting another
machine
Aug 21, 2012 | Janome Sewing Machines
The button holes that I want to do are larger than the automatic buttonhole will do on my Janome MS5027, is there a way that they can be done manually?
Mark your garment with chalk taking care to mark the start point and end points and a straight line to follow. Set your machine up for a fairly wide bar tack (zig zag in place) Then position the needle left and set it up for a satin stitch (fairly narrow) slowly stitch forward until you get to the end mark. Then do another bar tack. At this point you move your needle to the other side and satin stitch in reverse until you get to the first bar tack.
I would test this on a scrap piece first. Then proceed.
Jul 25, 2012 | Janome Sewing Machines
Janome 2030 QDC How to predict whether the buttonhole (24) will start forward or backward? I power off the machine and reselect stitch 24 and move the buttonhole presser foot to the start position every...
does it sew buttonholes both ways?
My Janome 6500 always buttonholes away from me, so when it starts, it sews the near bartack, then stitches backwards down the right hand side of the buttonhole. It then comes back with little straight stiches on other side and sews the zigzag backwards on the left side, then the far bar tack. I would have thought your Janome would do the same stitch sequence.
Jul 16, 2011 | Sewing Machines
Can't figure out automatic buttonhole use on MC4000
2 things must do:
You have to use the buttonhole foot.
You have to pull down the lever to the lowest position (just left of needle bar/ presser bar up in machine.)
Set to buttonhole. After each buttonhole, be sure to change off the buttonhole then reset to buttonhole to reset the buttonhole to the beginning
Mar 15, 2009 | Janome Memory Craft 4000 Sewing Machine
I keep getting the bl sound when trying to make automatic button
I'd forgotten to pull the little lever down that abuts onto the buttonhole foot! Simple!
Nov 28, 2008 | Janome Memory Craft 9000 Computerized...
Buttonhole
When a machine does an "automatic buttonhole the feed does not move for a few stitches and maay jam if there are too many stitches made in this position. Is it an automatic buttonhole or can you choose how many stitches for your bartack? You ask about 0.5 well that is halfway between 0 and 1 on the stitchlength and this is indeed the recommended setting for buttonholes. If you are doing a manual buttonhole set your machine to this for the sides and zero for the bartacks but you only need about 6-10 stitches on the bartack. Fininsh it off securely by setting to straight stitch and stitch length zero for about 4 stitches to lock the thread in.
Jun 25, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
82 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
