Question about Panasonic PanaFlat LC40 (White) 14" LCD Monitor
Panflat lcd lc40 with no power lead ...where can get one 19v?
Would a 19v 3.16a power supply suits a lcd monitor 19v 2.6?
Yep, that should do very well. The voltage (19V) is critical - that should match exactly. The current (3.16A, 2.6A) isn't so critical, but the power supply MUST supply AT LEAST as much current as the monitor requires. The extra current capacity won't hurt anything at all, it just won't get used for anything.
Aug 01, 2014 | Acer AL1916W 19" LCD Monitor
Hi, I have a Polyview V293 LCD Monitor with a power supply output of 19v 3.42A. The power supply has failed. Most i have found being offered as direct replacement for this monitor have an output of 19v...
If the power adapter is a separate from the monitor then check the monitor's label on the back of the screen for the power rating.If the rating on the label is greater than 3.16A then I would not purchase this adapter.
I suggest you purchase an adapter with a current rating greater than what is stated on the monitor's label.
Check out this WEB site for power adapters - a 19Volt 90 watt = 4.7A power supply is suitable.
http://www.cheaperoz.com/z/result.jsp?ga=sc1&q=19v+power+adapter
Apr 01, 2011 | Amptron POLYVIEW 19" Monitor
What type of cable power supply do I need for a V7 L17PS monitor? I got this monitor for free but no cables came with it. Thanks
Looks like it takes a 19V 3.42A Power supply.
Look on the back of the monitor near the power jack and find where it says "input"
If it says 19V 3.42A then this is what you want:
http://cgi.ebay.com/19V-AC-DC-Adapter-Power-Video7-videoseven-L17PS-LCD-/110632100842?pt=LH_DefaultDomain_0&hash=item19c22fe3ea
Mar 25, 2011 | Videoseven L17PS 17" LCD Monitor
What size is the power socket lead is it 5.5 outer and 2.5 inner thanks for your help
From my repair experience, 5.5 OD and 2.5 ID is commonly use on the power supply adapter since 2.5mm is made to handle higher current than the 2.1mm (2.1mm is usually for 2A or less).
Center is also positive.
But your can also be 6.5mm OD x 3mm ID. I would try Radi Shack, that is where I get the DC barrel connector in case of emergency repair.
http://lcdpayless.com/productpage.php?productId=4538
http://cgi.ebay.com/19V-AC-DC-power-Adapter-for-Video7-videoseven-L17PS-LCD_W0QQitemZ120609198174QQcategoryZ158844QQcmdZViewItem
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 16, 2010 | Videoseven L17PS 17" LCD Monitor
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
How do I delete a picture on the Panasonic LUMIX DMC-LC40
When reviewing the images on the LCD with the image you want to delete showing on the screen you push the button that has a trash can icon. The camera will ask you if you want to delete the file yes/no; scroll to yes and use the right arrow button to confirm.
Nov 27, 2008 | Panasonic Lumix DMC-LC40 Digital Camera
Camera's LCD screen goes black every so often
No. All Lumix® Digital Cameras have a built-in feature to conserve battery power. After a certain amount of inactivity, the LCD will power down to preserve the battery. Simply hit the SHTR button, and the LCD will turn ON.
Aug 31, 2005 | Panasonic Lumix DMC-LC40 Digital Camera
Panasonic PanaFlat LC40 (White) 14" LCD Monitor Logo
22 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
