Question about Kenmore 42161 / 42169 Electric Single Oven
Oven alarm f 10; what is this and how to make it stop alarming
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 27, 2010
Oven keeps beaping and has a alarm symbol showing
Sounds like the timer was set and time is up, the issue is whichever model oven it is has a specific way to stop the alarm. Some just require a simple pressing "cancel" while others use a combination of buttons. I would try pressing either the arrow up or down, if not present just press the "timer" button, see if the alarm symbol changes or disappears
Nov 10, 2016 | Ovens
How do I increase the volume in my oven alarm
Best bet would be to call an electrician and say specifically:
'Can you install a louder alarm in my oven'
You'll get asked about what brand and model it is, but what you can tell them is "Put another mains voltage alarm in parallel with the existing alarm"
If they don't understand that, call another company.
Nov 24, 2015 | Candy Ovens
An alarm continues to sound day and night , how do i stop it?
Unplug the mains suppl . This should allow the memory to decay naturally..
Aug 03, 2015 | Ovens
The F1 error code is lite and alarm noise won't shut off. turned off breakers and the alarm stopped upon turning back on but F1 lite is lite.
With your model & Serial number you should be till able to order the EOC (Electronic oven control). But they are not cheap.
Mar 17, 2015 | Ovens
The alarm turn on by itself when the oven is off, F2Code
Faulty signal that is going to the alarm driver to trigger off the alarm. The possible fault is the switching circuit, possible a leak in this semiconductor that is causing this issue.
You will need to go back to trace from the alarm buzzer backward to the driver. Since all other features are working fine, it can be only the faulty trigger.
Disconnect alarm if you think the fault is beyond you to avoid this annoying fault.
Helpful?
Aug 21, 2010 | Maytag CWG3100A Gas Single Oven
Cannot turn off the alarm - show F1. I turned the power off for 2 days - no help. When you hit clear off - it stops for 10 or 20 seconds then back on.
F1 code
This code usually means that there is a problem with the keypanel. Many times, it means the keypanel needs to be replaced
Good luck and please rate 4 thumbs for the free answer
Mar 11, 2010 | GE JTP45 Electric Double Oven
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Ge profile double wall convection oven
My solution for the F7 problem may work for you. It won't cost you anything to try it. It is simple and free. You can find it at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
Please let me know if this works for you. You can email me at:
hutchipop@yahoo.com
Good Luck,
Powerman
Feb 03, 2008 | GE Profile JTP18 Electric Single Oven
Alarm won't shut off
did you try turning breaker off then on after 5 secs or clear cancel or stop
Dec 12, 2007 | Jenn-Air JJW8530C Expressions Collection...
Kenmore 42161 / 42169 Electric Single Oven Logo
29 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
