Question about Pioneer CDJ-800 Turntable
CDJ 800 JOG WHEEL IS not working
Hi the jog wheel at my cdj is not working anymore vinyl mode is fine but there is no change in the speed when i turn the jog wheel. the pitcher is still working
  • Nayalex Jun 10, 2008
    the cdj is in dj mode but its stll not working
  • 68 Answers
Sounds like the jogwheel sensor,if you havent had it repaired you can send it to us.
thanks.
http://www.audiovisualservices.info/
Posted on Dec 03, 2008
There /s a switch with back of zhe set ,pls turn it to dj not normal
Posted on Jun 06, 2008
  • HMWDJCAT Jun 11, 2008
    tuch the jog key it will lighting on ,if it not light the key switch is NG
    my english is pool,would you talk it about in chinese
Have you tried updating your software it could work?
Posted on Jun 04, 2008
Hey! my CDJ is playing and stopping, playing and stopping not in any sort of pattern either. almost like someone is touching the top plate in vinyl mode. it happens aswell if you try and slow down the...
Hi, if you mean the fault occurs in the cdj vinyl mode and your cd dosent play... then it sounds like your jog wheel sensor membrane. but would have to be checked firstly by an engineer.
if you live in the uk then you can send your pioneer cdj for repair to www.audiovisualservices.info
Hope this has helped you.
Feb 14, 2011 | Pioneer CDJ-1000 CD Player
800 mk 1 plays in cd mode but once vinyl button is pressed play stops. even if I press the play button. The unit still jogs fwd and back just fine in vinyl. The case i use on occasion puts pressure(maybe...
You are almost certainly correct re "pressure switches"
Pioneer call this part "sheet switch" and it is a circular plastic "sandwich" of multiple contacts and when constant pressure is put on it, it tends to stick together giving the effect you are pressing it when you're not.
The part will cost you about £30.00 + fitting - unless you are confident enough to do it yourself
email me if you would like to order one. mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 25, 2010 | Pioneer CDJ-800 Turntable
My jog wheel sticks / doesn't glide like it should...
I had the exact same problem. I was working a party when some drunk ******* spilled some beer in my coffin case, thus getting into the jog wheel and cue button. I continued to work with it for a few months but got pretty fed up and brought it to a pio dealer. They fixed it up quick and cheap, now it glides like my other mk3s. I'd say bring it in a get a quick quote.
Mar 31, 2010 | Pioneer CDJ-1000 CD Player
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Pionee cdj-100s jog seems to be lagging
pull the jog wheel off and give it a clean and some grease on the shaft, also don't push it back down the whole way
Aug 26, 2009 | Pioneer CDJ-100S CD Player
Jog wheel hesitates when i release it
in dj mode they are ment to act like turntables give a little push in the right direction when you release.
Feb 24, 2009 | Pioneer CDJ-800 Turntable
Cdj 800 locking up on vinyl
There are very small wheels underneath the jog wheel, and these wheels are sitting on a plastic assembly, which has a tendency to break over time. More than likely, you'll have to have this repaired by an authorized service technician.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Dec 28, 2008 | Pioneer CDJ-800 Turntable
Displays gone on CDJ800
It sounds like a power supply to the both display pcb's is missing, unfortuanetly i wouldnt recommend attempting to fix this yourself, if you havent had it repaired then you can send it to us.
Regards.
Dec 11, 2008 | Pioneer CDJ-800 Turntable
CDJ800 vinyl modus
Hi Mate
My last post was a CDJ with a separate fault, causing a similar type fault.
99% of the time, this particular fault is the Flac switch under the platter jog wheel, take the jog wheel apart clean the plastic strip that runs around the jog wheel, the one with rubber feet that activates as a pressure switch.
Often there is air bubbles, liquid, condensation in between the two layers - causing it to stay in touch mode. If that doesn't fix it then you need to replace that strip (pressure switch). They are about £30 quid.
All the best and good luck
Dec 04, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
508 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
