Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We have an Intex above-ground frame pool (18' by 48") with salt water system. The water is never clear. Before we used to be able to see the bottom of the pool, now we can't. We just recently bought a stronger pump because generator was always saying "low flow" and we change the filters and clean the generator. If the green chlorine light is "on" on the generator, what does it mean? Can't find information in the book.
  • Intex Master
  • 8,404 Answers
I suggest you get a product called filter aid ... use it according to package instructions. Let your filter run for a couple days 24 hours ...
Posted on Aug 27, 2010
Can intex krystal clear saltwater system be used on 12000 gal. above ground pool?
personally, my opinion is no. if you have a real pool, get a real salt system.
Sep 08, 2014 | Intex Automatic Salt Water System for ...
Can I use pool salt in my summer escapes pool?
if you have a salt system add salt but you have to shock pool to get it clear
Jun 09, 2014 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System For Above Ground Saltwater Pool won't turn on
Usualy if it is some years the ball bearing on the motor shaft are rusty and if you can desasemble and use a UD40 lubricant or similar it can be fixed, or replace the bearing. One more posible case is the starting capacitor if it replaced can run the motor again.
Jun 05, 2012 | Intex Automatic Salt Water System for ...
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Jul 22, 2011 | Intex Automatic Salt Water System for ...
Cloudy water after running system for 15 hours
yes ... do you have filter media insyalled and the proper amount of salt installed?
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Pool pump shutting off/tripping the circuit breaker
What kind of pump are you using?
Sounds like the Intex is restricting water flow there by heating up your pump and shutting it down..
You may need to re plumb everything to handle the flow.
Intex hoses and fittings are different than the industry standards just so the can make you buy from them
Do what ever it takes to get good flow
Jul 01, 2010 | Intex Automatic Salt Water System for ...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
How much salt for 7000gal or 18x52 intex steel frame pool
To start up you'll need 175 pounds (80 kgs) When the Low Salt light comes on, add 45 pounds (20kgs)
May 22, 2010 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
114 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
