Error code 6000 is showing on the lcd screen how fix problem?
  • 1 more comment
  • Anonymous Jun 06, 2008
    error code 6000 is showing on my screen
  • laszlo_26 Oct 27, 2008
    I am frequently getting error code 6000, It stops printing mid job and comes up with this problem and I have to turn it off then on again. Starts up with a grinding noise, spits out the unfinished print page and then I have to restart the print job. Getting really annoying and I don't know the solution!!
  • rareburt Jan 09, 2009
    Error code 600 on PIXMA Connon MP830 Printer cartriges will not automatically slide to left when lid is lifted to repalce empties.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
What model printer? 6000 codes are usually related to the fuser section.
Posted on May 11, 2008
5 Suggested Answers
SOURCE: error code 6000 is showing
I had the same problem and went searching - all the feedback suggested that something may be stuck of blocking the paper path. Took the tray out, checked underneath etc - and yes - the problem was a couple of sheets of paper stuck inside. Was able to retrieve these by accessing them from the rear of the printer - and when plugged back in it started up ok!
I believe the cause here was that a print job was sent to the printer while it was also being used to copy stuff - though i cant be sure of this. Either way, it was a blockage that cased the problem.
All the best - JB
Posted on Mar 26, 2009
  • 987 Answers
SOURCE: service error 6000
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
Posted on May 10, 2009
sys_admin
  • 829 Answers
SOURCE: pixmax mp620 error 6000
Have you checked for paper jamm in the rollers or any other small item like a paper clip? Also are you running this on wired or wireless connection?
unplug the printer, turn it upside down and shake a little. If a tiny piece of paper could be to blame.
Posted on Jan 13, 2010
  • 284 Answers
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
Posted on May 27, 2010
Canon image RUNNER 6000 Copier error E 000001-0000
there is a problem in fixing unit. You can try to reser error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component is fixing assy. The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Aug 22, 2011 | Canon imageRUNNER 6000 Copier
My canon ir 6000 is showing an error codes E000001-0000 How it will solve?
Your error code is for the fixing unit solve by checking the follwoing:-
1. Fixing lamp.
2. thermistor
3. Fixing assembly if receiving PD
5. if no Potential difference received they the power supply is not okey.
Jul 13, 2011 | Canon imageRUNNER 6000 Copier
My Canon MP980 is showing Printer Error code 6000. Have turn off machine and turned on again - no change - still showing.
May 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error message one brother mfc-5440cn
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number
is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the
annoying cannot clean message.
Oct 28, 2009 | Brother MFC-5440CN All-In-One InkJet...
Unable to clean,check manual
Oct 25, 2009 | Brother MFC 210C All-In-One InkJet Printer
IR 5000i and iR 6000
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
Jan 21, 2009 | Canon iR5000-6000-L1 PS Ver 1.0
My printer shows error 6000 on the lcd screen. How do I fix it? at the moment I cannot use my pinter scanner fax.
If this is a Canon printer, then this indicates a paper jam. Ensure the paper path is clear and no debris is present and that no sheets of paper have gotten in a bind in the printer. If the paper path is clear, you'll need to contact canon for service/repair of the printer.
Oct 22, 2008 | Computers & Internet
My Canon Pixma MP170 printer is showing error code 5800, What must i do to fix this?.
MP170 (5b00) Ink Tank Full Error Reset
1,power off.
2,hold stop/reset ,hold ON/OFF
2,release stop/reset, push stop/reset twice, quickly, then release ON/OFF
3,wait untill LCD display shows "Canon Idle",then push stop/reset four times, quickly
4,then push power twice, quickly
5,power off and power on.
Jul 15, 2008 | Office Equipment & Supplies
538 people viewed this question
k24674
