Question about Canon ZR830 Mini DV Digital Camcorder
My video camcorder is canon fs2oo 7 i have a sd card 8gb inside now & i have recorded about 2.5gb already. now as soon as i turn the camera on i get message display saying the card is set for erasure prevention & i cannot record or take pictures. how do i correct this please
  • 3 Answers
There is a little switch on the side up and try then it will work
Posted on Nov 20, 2011
Can't get full use out of 8GB SD card.
There is no problem. The camera can only create video clips up to 4GB in size. You can record two long clips, but no single clip can exceed 4GB.
Mar 24, 2012 | Canon PowerShot A3100 IS Digital Camera
Have new Vivitar DVR810HD Digital Video Camcorder, loaded SD card correctly but camera does not record onto SD card Help!
Make sure that the video camcorder was not turned off immediately after recording before the images are saved in memory. Also be sure that your memory card is properly inserted in your camera.
Feb 27, 2011 | Vivitar DVR 810HD Flash Media Camcorder
Can I record video onto the Micro SD card instead of the tape using this camera?
mabrickman:
From the Canon brochure for this camera, the SD Card is only able to be used for saving still images.
Thanks for using FixYa
Feb 17, 2011 | Canon VIXIA HV30 DV Camcorder
When trying to record video, within about 15 or 20 seconds, a message saying, "Too Slow Card," comes on the screen and the video quits
This camera can use SD or SDHC cards up to a maximum of 8GB (gigabytes). These cards come in different "class" ratings. A class 4 card will provide faster access than a class 2 card. Video cameras like faster access cards and some specify that the card should be class4 or class 8. The card will have a number printed on it, maybe inside a capital letter "C" if it is faster than a class 1.
The manual for this camera does not specify a minimum class rating for the card.
Jan 20, 2011 | Vivitar DVR 810HD Flash Media Camcorder
When i try to format the SDHC 8GB memory card the recording screen display's (Waiting....) for about 1 to 2 second's, then goe's to the normal recording screen and when i push the record button it...
Hi, look here's what to do, get yourself, or access to, A Computer, and a USB SD card reader, now, insert your 8GB SD card into the reader/writer, It will show up as a HDD in My Computer, and then, Format it FAT32. Now return it to the Camcorder, when turned on again, the Camera NOW should "See" the SD card. You may even be asked if you wish to Format,again,say YES, and do so, if NOT asked that;s OK too. as, you should now be able to, in either case, be able to have access to the SD card, and can change your phone settings accordingly, the extra storage will simply be "Picked Up" by the Camcorders software.
If this doesn't happen, then there maybe a problem with THAT SD card or the Camcorder? try another SD card before thinking the camcorder has a problem though.
Aug 29, 2010 | Jazz Cameras
I have inserted an 8gb SD card and it will not record
If it is 8GB, it is an SDHC (high capacity) card. The protocol for SDHC is different than that for an SD card. SD card protocol handles a maximum of 2GB. This camcorder came out in 2003, well before the SDHC protocol was developed, and the camera is not compatible with it.
Feb 05, 2010 | Canon MVX10I Mini DV Digital Camcorder
My camcorder will only record in 10 second intervals
There is a 10 second limit to the SD card recording. pretty useless, but that is how it somes from the factory
Apr 11, 2009 | Canon Optura 20 Mini DV Digital Camcorder
I have a new Jazz DV151 camcorder and the memory card says full
Here is what you do. You take out the tiny Memory card and blow on and it, and blow i the inside. Then insert memory card. Take out batteries and put the batteries back in. Push Power and Start Recording., Chaow
Dec 27, 2008 | Video Cameras
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
Sd card
Hi!
I'm happy to say that your camcorder is capable of recording to SD cards with capacities greater than 2GB, as it is SDHC compliant.
However, I must ask why the SD card capacity would be of interest in a camcorder like this, as it records its video to MiniDV tape, and its photo function is limited to low-res stills.
Hope this helps!
Nov 05, 2008 | JVC GR-D870 Mini DV Camcorder
Canon ZR830 Mini DV Digital Camcorder Logo
112 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
