Question about Gigabyte GA-945GM-S2 Motherboard
TV to PC problem I have bought a realview TV box witch is connected with a VGA Cable to PC. TV is working fine but when i turned off TV switch it not connecting to PC. Even no signal in monitor light, no booting screen. The same realview TV card working fine on another PC. I have also Gadmie TV box witch working fine on my PC. Please help me... My mother board is Gigabyte GA-945GM-S2, No Extra VGA card.
4 Suggested Answers
  • 4472 Answers
SOURCE: warranty
contact Gigabyte at and ask them directly. As they do not post it in specifications.
Posted on Jun 19, 2008
  • 81 Answers
SOURCE: Gigabyte GA-945GM-S2
check this link for the drivers which you want....
Posted on Nov 19, 2008
  • 78 Answers
SOURCE: enable to boot bootable usb drive,ga-945gzm-s2 motherboard
reset your bios inside your pc its a big watch battery take it out for 10 15 min then put back it if that does not work take out the battery again and if you see neer your battery was ther should be a small jumper its usually black and its plugged in your board it also should have 3 pins to plug it in when you take it out plug it in the next 2 pins (the miffle one will plug in aswell then put it back in the first pins again put battery back in an try to boot it should work...
Posted on Mar 30, 2010
How can I hook my dell latitude e6400 lap top up to old sony Trinitron with one vga cable connected to laptop has rca and s-video also on same cable only one side thoe
If I understand your configuration correctly, you have a VGA cable that plugs into your laptop and you want the other end to connect to your TV? They make a VGA to S-video converter box that you can buy to make the connection
Sep 23, 2013 | Dell Latitude E6400 Notebook
How to Hook Up a Laptop to a LCD TV by VGA cable?
First of all check out does both the LCD tv and laptop both have vga cable input socket This is the most important step, as it will allow you to buy the right equipment.
VGA cable is the standard 15-pin connection that you would use to connect a monitor to a PC or laptop. Use a VGA cable to connect your laptop's VGA output with the television's VGA input. Use separate audio connection with mini-jack (3.5 mm) to RCA adapter.
Turn on your devices. Once you've made the connections, turn devices on. Switch your TV to the input mode that corresponds with the input you used to connect your laptop, and you should now view your laptop on your LCD TV.
This will help.Good luck.
on Mar 08, 2010 | Computers & Internet
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
Sir, i have just bought a new lg 26ld310 model. I want to connect my PC to it(my pc does not contain HDMI). Waht would be te cheapest and best way to connect my PC? Thanks in advance Regards, Vinamra
Used ur computer VGA monitor cable.Connected to the computer video card port and the other side of the VGA cable connected to the LCD tv VGA video port.This will work fine too.
Dec 02, 2010 | LG Televison & Video
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
Jun 15, 2009 | Insignia LCDTV26 26 in. Television
Ok my Magnavox digitla converter box has been
Something is wrong with the box, you most likely will need a new one.
Jun 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
Gigabyte GA-945GM-S2 Motherboard Logo
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
