Question about Lexmark X4650 InkJet Printer
DSL line problems required us to reset the wireless router in the process the Lemarck x4650 no longer connects to laptop. Fix?
  • 4,924 Answers
Get t the wireless card of the printer ..and reconnect it in the actual conditions of the router ..just open the card ..and scan for network ..when you find it ..connect ...and insert the network password if it has the security activated..Practically connect the printer again like you connect a wireless laptop ..
If the connection is made to one of the ports of the router ..by cable ..than open the lan card in the printer and insert the values corespondent to the position in the port .. or put it to automatically (obtain an IP address automatically ) if the router supports it ..and it is not necesarry to insert the addresses a manually ....if it is ..get to the other option ..use the following Ip address ..and insert the values like in the computer that connects in the near by port ..only at the IP address insert the last digit with one unit more than the port near it ..like thi s..
if the printer is in the 4th port ..and the computer near it in 3rd has the Ip address 192.168.1 4..the printer will became ..192.168.1.5 (they are always with one digit more..cause the router is 1..the rest since the port one are from 2...3..and so on ..
Posted on Aug 26, 2010
I want use my 2wire (2701HG-B) Wireless Router without the dsl line
Modem and routers are considered only as access point you computer may be able to connect to your router but if you dont have a DSL line you will not be able to go on line... if you dont want a DSL line there are service that concentrates on wireless alone... in this DSL line are not required nor router but may provide you a USB wireless adapter that has their wireless service then again try calling an Internet Service provider for this options...
thanks... Roger
Jun 11, 2011 | 2wire (2701HG-B) Wireless Router
Dlink DI-514 dropping my wireless connections
Your router probably needs a firmware upgrade to accommodate the throughput from the ISP server.
1. check with your provider to see if you have issue with your cable or DSL line.
Sometime if it is a DSL line it is the drop to your house , ( rodent chews in the line; rain or moisture, or dangling and not secured.
2.Cordless phones to close to the router will cause disconnection.
3. A firewall setting in an anti virus software can cause disconnect if not properly configured.
4. channell selection will cause disconnect on some older router such as yours and an new router is the only remedy because the router has come what is called " end- fo -life " and the manufacturer no longer support the router because of new router technology implemented.
Jan 23, 2010 | D-Link DI 514 Wireless Router (DI-514)
LImited or no connectivity on wireless router after reset
hi
go to the router wireless settings and check to see if the wireless connectivity has been disabled as a part of default settings
cheers
Pls rate if this was any help
Jul 04, 2009 | Microsoft Wireless Network Adapter Xbox...
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
May 08, 2009 | NetGear DG834G Router
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Linksys wireless g router will not connect to the internet
hello jillyg70
my name is tazman
have you tryed calling linksys they can help you . but you might want to try going to 192.168.1.1 first this will get you in to your router so you can set the settings on it. it might ask you for a password its admin try this before you contact linksys if you have trouble setting it up we have a premium chat i can help you
hope this works
Jul 06, 2008 | Linksys Wireless-G Broadband Router
Ic help
Scenario 2 to 4: Scenario 2) The modem does not have an Ethernet port. The modem is a dial-up modem for traditional dial-up service. To use the Router, you need a cable/DSL modem and high-speed Internet connection.
Scenario 3) You cannot use the DSL service to connect manually to the Internet.
After you have installed the Router, it will automatically connect to your Internet Service Provider (ISP), so you no longer need to connect manually.
Scenario 4) The DSL telephone line does not fit into the Router’s Internet port.
The Router does not replace your modem. You still need your DSL modem in order to use the Router. Connect the telephone line to the DSL modem, insert the setup CD into your computer, and then follow the on-screen instructions
Apr 19, 2008 | Linksys Wireless-G WRT54G Router
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Lexmark X4650 InkJet Printer Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
