Question about GE 24 in. GLD5500L Built-in Dishwasher
GLD 5500, about 2 years old, has not run in over a year, just installed, takes on water, and drains properly, but will not start the wash cycle, turned power off at breaker and retried it and no change
SOURCE: PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Posted on Feb 20, 2008
SOURCE: GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Posted on Sep 23, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
SOURCE: GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Posted on Jan 20, 2009
plnolte
  • 62 Answers
SOURCE: no water in dishwasher
check the water valve it could be bad and not be letting water into the unit...let me know and I will further assist you.
Posted on May 13, 2009
I have a GLD 4456R00CS dishwasher that is maybe 6 months old. It seems to cycle properly, but has never really cleaned the dishes. This is the worst dishwasher we've ever had (over 25 years) and I'm...
Sorry you have had so much problems with this dishwasher. Before you "take it to the street" please check one more thing. I have had so many people say similar problems.
  1. Check that you are using rise aid if their is an adj. set it to 4-5
  2. Make sure the soap in the dishwasher is a name brand. Dollar store soap will only get white film and poor results
  3. Everyone should run there sink water for at least 2min before you run the dishwasher making sure the cold water is flushed from the line and hot water enters (better wash and shorter wash times)
  4. Water entering has to be at least 125 degrees always.
Also run a bottle of Dishwasher Magic once a month to clean out your dishwasher.
This should do wonders for your cleaning results. Have a super weekend!
Dec 11, 2010 | GE GLD4456RCS Builtin Dishwasher
Won't clean-looks to run properly
check the sump area below the pump and clean out any waste food debris,etc. and also the drain check valve,it may be plugged and not draining waste water completely or not closing completely and letting waste water back into the sump and this could be getting back through the pump and sprayed back onto your dishes
Jul 28, 2010 | Kenmore Dishwashers
I have a GE Model GLD 4260L dishwasher. It is noisy in wash cycl
Hey Roy, the main pump/motor mechanism that supplies water through the washarms is a seperate pump from the drain pump.
Try this since it sounds like your handy, I bet this diagram will help you.
Go to www.geappliances.com scroll down while looking over on the left side of the site and click on the quick link of parts and accessories, then scroll down and click on the picture of the dishwasher, scroll down to the box where you enter your dishwasher model number, click on either of the models that pop up( both are the same) then click on the little arrow next to the red go button,to drop down your choices, click on motor-pump mechanism,then click GO,then click on the red letters that say "click here to view diagram of motor-pump mechanism" and then an exploded view of your dishwashers pump and other units will appear,study the diagram and this should help.
Wow that was a long road, but hey I hope this helps you solve your problem. Good luck !
Jan 10, 2010 | GE Dishwashers
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
Washer won't drain
I don't know how it was fixed. I kept on running it through cycles and the water finally drained.
Dec 05, 2008 | Kenmore Washing Machines
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
GE 24 in. GLD5500L Built-in Dishwasher Logo
29 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
