Question about Garden
B&S 14.5 HP engine model 287707, type 1255-E1 I had to replace cylinder head gasket - what is the required torck on the cylinder head screw? There is 2 Push Rods - 1 aluminum and 1 metal - which one goes where? Thanks for any help,
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
  • 23 Answers
SOURCE: engine check light read p0171 and p0420, noticed a leak of engine oil on cylinder 2 area of head gasket when checking the sparks plug, is that the cause?
may be oil feed to cylinder head replace gasket
Posted on Apr 20, 2009
panilling9
  • 284 Answers
SOURCE: solenoid will not shut off gas when switch is off.
Have your mower running in park
pull the wire off off the solenoid if it is working correctly your mower will shut down less than 10 sec.
if not then it will have to be removed and inspected
sometimes the plunger gets hung up with dirt and or rust and or moisture
remove it and free it up manually and retry when you see it is not stuck anymore and operates without sticking
Posted on Jun 09, 2009
  • 376 Answers
SOURCE: How can I detemine type of stator in my mower without disassembly
If you have two wires coming from under engine shroud, a black and red, plugged into a connector with a white and black wire going to the mower, It's a Dual Circuit alternator.
Posted on Jun 29, 2009
  • 905 Answers
SOURCE: 2000 camry. blown head gasket (daughter drove car
Yes, you can, but not exactly recommended. If you are going to go that deep into it, then might as well do everything else. However, being unemployed tends to have a negative impact on the wallet....
I suspect it is more than just rings. I think that the walls have been scored badly as well. You may be able to use a borescope to take a peak into the cylinder through spark plug hole. Move the piston to bottom of stroke, and see what you can see. If scarred, much work will be needed. If hatches look alright, then you might be able to get away with just rings.
What kind of compression are you getting on #1 vs #2? This also might be a blown headgasket into an oil passage, or the head (perhaps block?) is ever so slightly warped in this area.
Posted on Aug 29, 2009
Testimonial: "Thanks for the quick response. Very much appreciated your input, all makes sense and got my mind on the right track again. Thanks"
What is the PN for the carburetor for a B&S 287707 1255-E1 engine?
any mower shop will be able to get the carby for you. if you ask nice they may supply the part number then you can take that and go e-bay for a cheaper carby
Nov 25, 2015 | Garden
I have a Briggs stratton 14 hp ohv I/c quiet model 287707. I had a guy change the oil & he put 10W30 synthetic oil in it. Now it smokes white smoke really bad. I think he put the wrong oil in
There is a very real difference between 30W and 10W30 oil. Whether it's synthetic or not probably doesn't matter. If you have the literature that came with the mower, it will tell you the recommended engine oil.
If they put in the wrong oil, they should make it right. You shouldn't have to pay twice for an oil change. It could be burning oil, since 10W30 is a lower viscosity than 30W. I would have them change it again, and see if it stops smoking.
Nov 24, 2014 | Garden
I have a Briggs engine 121602-0269-E1 and had to remove the head. Should I install a new head gasket and what in reinstall torque setting?
always replace head gasket if removed. torque value is 28.2 NM or 250lb/in the head should be torqued in 3 settings. do 1/3 then 2/3 and then final 1/3
Oct 15, 2014 | Briggs & Stratton Garden
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
Battery does not charge
Check all the battery connections, if they look good replace the battery.
Nov 19, 2013 | Briggs & Stratton Garden
I have a craftsman lawnmower with a 24 horse intek motor with the 4 screws holding air filter. it has started leaking oil at base of the left jug. it is leaking right at the bottom of it so i cant see...
I am assuming you are calling the cylinder the jug on the engine. If you think the engine is leaking oil from the cylinder you have to replace the crankcase. The cylinder does not separate form the crankcase as they do on atvs. If you see the leak at a gasket, it could be a blown head gasket, valve cover gasket or a sump gasket. The sump gasket is the gasket between the crankcase and the sump. The sump is the part of the engine the mounting screws thread into. The valve cover gasket is between the head and the stamped steel cover. Replacing the valve cover gasket is easy. Just remove the four bolts to remove the cover. Then clean the old gasket off. You can apply a thin layer of rtv to help seal the valve cover. The head gasket is between the cylinder and the head of the engine. If this gasket fails, the engine can burn oil and/or leak oil. The head gasket is more involved to replace. You need a set of feeler gauges and a toque wrench to do the repair
qf8hqfvfwspt07waaaaasuvork5cyiia
Oct 25, 2017 | Briggs & Stratton Briggs Stratton Intek V...
I have a mountfield sp470 petrol self proppelled lawn mower. the engine is briggs& stratton but i dont know the engine model. i need this as the cylinder head gasket has gone and needs replacing.
Hi. The SP470 has a 4 HP Briggs and Stratton engine.
The part number should be 687171 and you can look here:
http://www.worldofmowers.ltd.uk/Products/ProductList.aspx?search=Head+gasket+&type=3&searchBtton.x=20&searchBtton.y=10
Take a good look at the valve end of the head gasket. From the pictures on the page you should be able to see which one of the 4 head gaskets on the page is yours.
If you have yellow pages you can look up lawn mower repair. Or small engine repair shops. All of them should have this commonly used headgasket in stock. Just find one close to you or.. use the link above.
Here is yet another link for the head gaskets but you have to scroll way way down the page or page search for 698717 or 272171.
http://www.briggsbits.co.uk/acatalog/Horizontal_crankshaft_2-7_HP_Sidevalve_Engines.html
Thanks for choosing FixYa.
Kelly
Sep 12, 2010 | Garden
Bent push rods both cylinders,engine # 445677-0827-B1
You can find a manual, free of charge at www. briggs & stratton.com. click on manuals and put in your model and type and its free to d/l. You can then print it out if so desired.
Jul 25, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
320 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
