Question about Canon Pixma iP4500 InkJet Printer
Ink absorber is full. Can't print. Model iP4500.
  • 4,323 Answers
Hi
Check for the waste ink absorber, it would be on the right side of the printer where the cartridges reside when the printer is off. Make sure power is turned ON, open the front cover/door, and look for the waste ink absorber at the bottom of the printer head. Now switch off the power to the printer and press pad of absorbent towel on the waste ink pads. After this is done reset the printer---
1) Power off printer
2) Hold RESUME button then press and hold POWER.
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times
to reset the waste ink counter.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 26, 2010
Canon ip 4500 ink absorber problem
This mayclear the ink absorber problem. There is ink absorbers located at both ends of the printerwhere the ink head move.
To dry the ink absorber, power up the printer and open the cover so the inkcartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place itinside the printer over the ink absorber on the far left hand side of theprinter to soak up the excess ink. You may need to change the absorbent tissuea few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 26, 2011 | Canon Pixma iP4500 InkJet Printer
The ink absorber is almost full contact the service center
Canon iP4500
The ink absorber is full
Contact the service center
Apr 07, 2011 | Canon Pixma iP4500 InkJet Printer
INK ABSORBER FULL Printer model - pixma ip4500 Please solve my problem
This is from the Canon web site.
Before the ink absorber becomes completely full, contact a Canon Service representative. (You will need to replace a particular part of the printer.)
i_important.gif Important
Canon recommends that you call for service as soon as this error occurs. Once the ink absorber becomes completely full, printing cannot be performed until the ink absorber is replaced.
There are some links on how to clean it yourself or to bypass the alarms on this site. Just do a search for ink absorber and you should find them. I wouldn't try this unless you are mechanically inclined.
Aug 26, 2010 | Canon Pixma iP4500 InkJet Printer
How do I clean the ink absorber from a Canon Pixma iP4500 printer
First off, this is a VERY messy job. It likely requires full disassembly to chassis of the printer. The waste ink pad likely spans the entire foot print of the printer and is many pads thick, at least it does on other similar models. When we clean these, at a Cartridge World store, we rinse the pads, which are special dense felt material and then centrifuge the water and ink out, which can take multiple cycles. Low end ink printers generally do have have service manual readily available to aid in disassembly so you are on your own.
It is doable but be aware of what came from where and in which order.
Here are the instruction for how to reset the counter. Warning: Resetting the counter without cleaning the pads WILL result in waste ink overflowing out of your printer and onto whatever the printer is on, eventually.
http://www.printerclinic.info/2008/08/reset-waste-ink-absorber-error-waste.html
Mar 23, 2010 | Canon Pixma iP4500 InkJet Printer
This error : the ink absorber is full.
You do need a service center to repair that for you. The ink absorber is underneath the printer and covers the whole bottom of the printer. If you just do a reset it will soon overflow and ruin the printer. You need a shop to be able to enter the service mode and reset the counter after the absorbers are replaced.
Feb 07, 2010 | Canon Pixma iP4500 InkJet Printer
Absorber is full
Hi ....
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... Cheers :)
Jul 15, 2009 | Canon Pixma iP4500 InkJet Printer
Ink absorber full
You can probably do this once as the ink absorber will start to expel in onto the place where printer is on.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
6. turn off printer by button POWER.
Jun 20, 2009 | Canon Pixma iP4500 InkJet Printer
Waste ink absorber almost full. What do I do?
Hi ...
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
My canon ip4500 says that the ink absorber is full contact the service centre
Hi ....
Do vote if this helps ... Cheers :)
Apr 29, 2009 | Canon Pixma iP4500 InkJet Printer
Canon Pixma iP4500 InkJet Printer Logo
358 people viewed this question
old marine
old marine
