Question about Rowenta DG-980 Iron
I have a Rowenta DG-980 steam generator. It spits little grains of something when I use my iron. It doesn't hurt my clothing, but I have to brush the stuff off my clothes when I am finished ironing them. I think it is calcium build up in the generator. How do I clean my iron of this stuff without ruining my wonderful iron?
    Scholar:
  • 70 Answers
Hi, Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion. To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time). After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water that was is in the system. Hope this helps :O)
Posted on May 13, 2008
  • Jo Pomeroy
    Jo Pomeroy Jul 24, 2016
    I have the DG 980 and the instructions say to use tap water. Distilled water is a much better choice.
Shoots out through the steam vents and sains clothing
The symptoms you describe are indicative of mineral buildup in your iron. The instructions probably say to use distilled water in the iron and may include a procedure for removing mineral deposits
Jan 14, 2013 | Rowenta DG-980 Iron
Sand like particles come out when pressing the steam button leaving grit all over my clothes
I'm guessing that these particles are white or almost white. If so, it is just a build up of chalk from hard water. You will probably find that they just brush off the clothing with your hand. Just buy yourself a proprietary steam iron descaler and follow the instructions, all should be well
Jul 18, 2011 | Rowenta DG-980 Iron
My Rowenta Expert steam generation iron (seperate tank for the water type) is starting to spit ever so often brown water out. I only use filtered water. How can I clean the actual Iron, the water tank is...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Mar 16, 2011 | Rowenta DG-980 Iron
DG 5030 steam generator-first time used and after...spits water
Common problem if you have the temperature or steam setting set too low (not enough heat/steam to vaporize water droplets or the unit is not up to full temp. I would have a clean towel alongside the iron to give a burst of steam prior to your first press...
May 29, 2010 | Rowenta DG-980 Iron
How to clean iron
You can clean inside iron by open the cover and used brush
Jun 26, 2009 | Rowenta DG-980 Iron
What should I do ?
The old Rowenta DG-980 is a consumer grade machine but with commercial quality function and features. My gal who worked at a dry cleaners many years ago loves the DG-980. Here is the scoop on how to get it going if just cleaning it is all it needs (our used one had the same problem and I fixed it by doing the following:
After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water and debris that was is in the system. Hope this helps :O)
Aug 12, 2008 | Rowenta DG-980 Iron
New face plate
Google California Electric Service in California, they are on Burnett Ave. Sorry I am having problems posting solution with my ISP connection.
Aug 04, 2008 | Rowenta DG-980 Iron
Missing hose for cleaning
In California, the name of the place is
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
You were unclear if the faceplate is on the steam generator or the iron. Anyway the repair center for Rowenta above should help you. Be prepared to pay for shipping, get a firm estimate and insist on old parts be returned with the repaired unit. If it is the soleplate assy, it is around $75 or so.
Jul 30, 2008 | Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
540 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
