I have a Hitachi 51SWX208 Project TV. Recently the the red color is not converging correctly and is warped on the screen. I understand this is related to a ahrdware failure. Can you suggest how I can fix this myself? Thanks.
  • chennapan May 06, 2008
    Sorry the Model Number is 51SWX20B. Thanks.
  • chennapan May 14, 2008
    Hi Maanita,
    I tried you suggestion of powering off and on. It did not help. I noticed that the link you provided for downloading manual takes me Hitach inverters instead of the TV manual. Thanks.
    Chennapan
  • 2,326 Answers
If you intend to fix it yourself, I would suggest to call Hitachi and ask for a convergence amplifier assembly.
Provide them with the model and chassis number of your TV.
If they are unable to help you with the assembly let me know to walk you throught the repair precess and the parts that will need to be replace.
Posted on May 06, 2008
    Genius:
  • 1,142 Answers
Try a hard rest first...unplug external power to the tv..keep it switched off for about 10 minutes..then turn it back on.
    Genius:
  • 1,665 Answers
You need a service manual
My Hitachi 57F59A projection tv has a yellow color to it. I have ajusted the color and tried to reset and start over but still yellow. What could b wrong?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 04, 2011 | Hitachi 57F500 57" Rear Projection...
I have a Hitachi and the red in the upper corner is drooping
  • Screen looks 3D
69189a5.pngSOLUTION
May 03, 2011 | Hitachi Televison & Video
Hitachi ultravision 50ux26b. Two problems. 1. In the top left corner it looks like a dogear with the picture behind it faded and the edges looking blue.This started shortly after a couple of moves...
  • Screen looks 3D
69189a5.pngSOLUTION
Apr 21, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
Hi there, I have a hitachi 53" projection tv and
  • Screen looks 3D
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 31, 2011 | Hitachi 53UDX10B 53" Rear Projection...
We just bought a Hitachi 65S500 tv secondhand. When trying to correct the convergence, the magic focus green color does not align the letters correctly in the horizontal position. When we try to correct...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Hitachi 65S500 65" HDTV-Ready Rear...
I 53" Hitachi Projection TV and I get double
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 10, 2011 | Hitachi Televison & Video
Colors in left upper corner like a rainbow and fuzzy warped picture with lines that will run thru the picture from time to time, majic focus does not clear this up and I can not get the color set...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 06, 2011 | Hitachi 50SBX78B 50" Rear Projection...
Hey there recently my screen just went haywire and i am seeing double and the second picture is red in colour,also the bottom of the screen is curved....what causes this and is it worth fixing?
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 23, 2010 | Hitachi 50UX57B 50" Rear Projection...
We have a Hitachi 53udx10b tv. Recently it was
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Dec 05, 2009 | Hitachi 53UDX10B 53" Rear Projection...
RED WAVY LINE THROUGH SCREEN OF HITACHI 57F500 REAR PROJECTION HDTV TV
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Dec 02, 2009 | Hitachi 57F500 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
