Question about Ricoh Office Equipment & Supplies
Flashes Sc 345 - Ricoh Office Equipment & Supplies
  • 52 Answers
Reset the memory
Posted on Aug 27, 2010
Alpine 345 amp flashes VLT
If the fault occurs even with the engine switched off , there is no reason of excess voltage but if the inverter DC-DC convertor within is faulty it can cause this error.
You can remove the covers and check for any visible signs of capacitor leak or burning. Unless the circuits are isolated the fault cannot be traced or confirmed. It can be a short in any of the regulators or drivers but has to be confirmed.
Dec 23, 2011 | Alpine Car Audio & Video
As flashing red light
Flashing red light indicates a hard ware problem.
In MOST cases it's a problem with the PS3 motherboard. You can try booting without the hard drive inside, but it's rarely the cause.
Time to call Sony. 1-800-345-SONY
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Alarm light is flashing, data says check printer, press resume. ##345 comes up also.
##345 is jammed cartridge error.
Look for any obstruction or foreign matter in the area of the purge unit.
If this not help you may have a problem in purge unit.In this unit there is an axis which broke.You need to replace the Purge Unit.
Oct 12, 2009 | Canon MultiPASS MP700 All-In-One InkJet...
Sc 345 problem
you have a fuser code you need to have a tech come out and test the thermistor, lanp, and thermo fuse.
Sep 28, 2009 | Ricoh Office Equipment & Supplies
Receive message 345 and alarm which prevents operation.
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Sep 25, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Nikon SC-29 REMOTE CORD
Hi Kathy,
Are you ready?
1. Make sure the Nikon SC-29's Red Panel's Lock Switch is set to the Left. Pointing at Left Black Screw.
2. Connect the Nikon SC-29's (Red Panel) to your camera's Hotshoe by pushing it as far as it goes.
3. Turn Lock Switch to the Right (turn CW). This locks down to camera.
4. Make sure Nikon SC-29 (other ends) AF-ILL is set to OFF.
5. Make sure your Nikon SB-800's Lock Switch is set to the left side.
6. Attach your Nikon SB-800 into this Hotshoe.
7. Switch the Lock Switch on flash to the right.
8. When you wants to AF from flash, set AF-ILL to "OFF"
9. For the best results, set AF-ILL to "ON".
I teaches, do repairs, services and modifications on all photographic equipments.
I hope they are helpful to you as well as for any Nikon Photographers using the Nikon SC-29 Cable.
Mine has Autofocus, ITTL, Slave and Wireless Radio Remote Flash.
Truly,
atdlee@netzero.com
Jan 31, 2009 | Cameras
Jammed at far right (error message ##345)
hi
I don't know if you have the same problem as me but my printer kept saying cartridge jammed so I opened it up and moved the cartride head gently to the left and got a flash light there is a little peice of metal on the base where the cartridges sit you have to make sure it is cliked back in and now mine works again.
I hoe this helps
Sep 20, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
TTL Multi-Flash Sync Cord SC-27
YES YOU CAN BUT WHY NOT SET THE CAMERA IN THRE ITTL COMMANDER MODE
AND SHOOT THE FLASHES IN SETTING 4A
NO CORDS NEEDED THEN .
BERRIE SMITH CAMERA REPAIR
BBMW@BELLSOUTH.NET
Sep 19, 2008 | Nikon Speedlight SB-800 TTL Flash
Panasonic TH-42PX60B
THE 10 flash code is for the power supply
The Seven flash code is for the SC pcb (ysus) it is best to change the SC, SU, SD pcbs as one can take one of the others out
and if you add a new SC and one of the others is faulty then you will have another dead SC pcb
May 03, 2008 | Panasonic TH37PX60 37 in. Plasma...
211 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
