Question about Car Audio & Video
I need the location of the horn relay on a 1989 corvett.
  • 19,396 Answers
Hi.
In post 84 models is located in the convenience center in the junction box below the instrument panel to the left of the steering column. . See here.
Here the part.
Posted on Aug 26, 2010
1989 Cutlass Ciera Where is the horn located to replace it? Fuses are fine.
Did you check the horn relay! it is in fuse box under hood. God-Bless! if the relay is bad horn will not work. It should be be behind or near the passenger side head light.
Apr 24, 2015 | 1989 Oldsmobile Cutlass Ciera
Horn relay location
30 years old. Yours doesn't have on. You'll probably have a fuse. If that isn't blown, then replace the horns or it is in the steering wheel. You can check the horns by supplying power and ground the electrical connector.
Aug 26, 2014 | 1984 Chevrolet Corvette
Where is the blower relay switch located in a 1989 corvette
there is none, instead there is a blower motor control module:
Dec 17, 2013 | 1989 Chevrolet Corvette
Corvette horn not working
I have a 1999 corvette and the horn will not blow when pushing on the horn pad. It beeps when locking the car and security system.how do I locate the problem. Thanks Bob
Jul 12, 2012 | 1986 Chevrolet Corvette
Were is the horn relay switch located in a 1996 corvette coupe?
The horn relay is located behind the drivers info center. It is in the center of the dashboard. Remove the bezel and controls and you will see it. There is also a fuse there.
Jul 26, 2011 | 1996 Chevrolet Corvette
Where is the fuel pump relay located on the 1989 corvette?
It is located just to the right (toward the passenger side) of the brake master cylinder/booster.
Apr 14, 2011 | 1989 Chevrolet Corvette
Horn doesn't work on 2000 Corvette - Where do I start to solve the problem?
First u need to check horn by direct battery supply, before that u can try to hear the horn relay sound. If horn & horn relay is ok then u can check steering horn switch/ Ribbon. Wel, is there glowing chk light ?
May 16, 2010 | 2000 Chevrolet Corvette
Horn and cigar lighter not working on 1982 corvette - need wiring diagram
Visually inspect horn make sure its not corroded and wiring is on it tight. Then use a voltmeter and when horn button is depressed 12v should register on the meter. If 12v are there and horn doesn't sound the horn is defective. If 12v does not make it there then its either the relay or clock spring (located inside steering wheel) most likely. A visual inspection should pretty much do it with the clock spring (corrosion ,wear of contacts). Relay must have B+ going to it at all times and coming out only when horn is depressed. good luck
Oct 27, 2009 | 1981 Chevrolet Corvette
Cannot find fuel relay 1989 corvette
UNDER THE HOOD FUSE PANEL LOCATED NEAR THE PCM.
Jun 09, 2009 | 1989 Chevrolet Corvette
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
