Need a manual for programming the thermostat for the ac/heating in our office. it's a DICO model 1F82-273. Thanks, Brenda
4 Suggested Answers
liteswink
  • 99 Answers
SOURCE: I need an owners manual for Model # 1F82-261. I
This is the correct link for the manual of the 1F82-261 it's a pdf file.
http://www.white-rodgers.com/wrdhom/pdfs/instruction_sheets/0037-6175.pdf
Posted on Oct 16, 2009
vetteman3002
  • 2299 Answers
SOURCE: Hi, We had a guy out
I don't have a wiring diagram, but I can tell you how it is wired. I don't know if you would be interested in me just telling you. Let me know. The blower fan is completely different than the AC. The blower for the furnace is wired through a thermal couple in the heat exchanger. And then goes through the control board to a relay that turns the fan on.
Posted on Nov 01, 2010
  • 185 Answers
SOURCE: my 1f82-51 thermostat has no
Change the battery if the thermostar has them. If not then the 24 volt circuit may not be working from the furnace. Does the furnace have 110 volts to it. Are the breakers all on.. Is the SSU at the furnace turned On if it has one or is the fuse in the SSU OK. If all of this is OK then try a quick test. Take the Thermostat off of the subase and put a jumper wire from R to G if the blower comes ON then the thermostat may need to be replaced...... This process will work for any type of thermostat that is acting up... Hope this helps
Posted on Jan 31, 2011
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
I have the progarm set to heat on at 5:00 AM It starts at 4:00 - 4:15. If I change the start time it does the same, stays 45 minutes to an hour earlier. The programs has always worked unitl a month ago....
The thermostat is probably set for that. Most stats have option of starting at your set time or being up to temperature at your set time. If you have you stat manual set it to regular recovery not adaptive recovery
Jan 23, 2011 | Heating & Cooling
I set the tstat manualy for 77 and when we wake up it reads83 what? thanks
You have a pre-programmed thermostat. You'll need to put in settings for each program setting in order to have the thermostat provide you with the heating/cooling temperatures you want at each time period of the day and for each day of the week (in the case of a 7 day programmable model.
Whenever you put in a manual temperature setting, it is only a temporary setting that will get reset at the next pre-programmed temp setting, unless you set the "HOLD TEMP" setting and select the number of days you want it to hold the temp you manually set on the T-stat.
If you can provide the model number, I can help you further with the programming of your T-stat.
Hope this helps and best regards!
Thanks.
Aug 05, 2009 | Honeywell Programmable Thermostat Heater
Program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
Nov 13, 2008 | Honeywell Programmable Thermostat Heater
I have a trane thermostat and I need help programming it
If indeed the program is stopping it you can find out by putting the thermostat temp on a manual hold. Set tstat to a desired temperature then push hold. If all works well then you will need to reset your program to fill your needs
Oct 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
136 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
