Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Runs but will not accelerate. All parts considerated are clean and fuel is fresh.
  • Troy Master
  • 7,482 Answers
Check your fuel filter in the fuel tank to make sure it is clean if it is then"
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
Problem with acceleration
More info?
Air filter clean, good spark plug and spark quality? Clean fresh, oil? Carb or injectors clean? Fuel filters clean and properly installed?
Engine and/or radiators clean enough to be cooled?
Feb 19, 2015 | Motorcycles
I can't get my blower to accelerate. It will only idol on full choke. If you pull trigger it bogs down. I replaced the fuel line and sprayed carb out.
Check the following, and then clean or replace:
  • Fuel Filter - Located INSIDE the Fuel Tank
  • Spark Plug
  • Spark Arrestor - at muffler
  • Carburetor - May need a rebuild kit
Watch this as well...
and...
Oct 18, 2013 | Stihl Bg 55
Engine lacks power when accelerating. Idle ok.
unfortunately when you leave for long period of time fuel in carbs turn to a gel you may have to clean the float chambers out and put fresh fuel also look for signs of rust deposits from tank
Apr 21, 2013 | Cars & Trucks
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have an echo shred e vac blower it won't start.i cleaned the sparkplug,tested the stop switch ok,it still will not turn over,
Do you get spark? Is fuel making it's way to the carb.? If no spark need new coil, if no fuel clean carb. and rebuild.
Nov 12, 2010 | Garden
Runs if gas poured into carb. won't pick up gas to carb. please help
Check the fuel filter and air cleaner for plugging, also the muffler if the saw has seen considerable use. Check the condition of all fuel lines including the one in the tank. Inspect the primer bulb for cracks or other damage. If still won't pump fuel after the above, remove the carburetor and check the small impulse air passage down to the engine for any blown gaskets or plugged passages. I'm assuming that the engine has good compression. Be sure to use fresh fuel/oil mix. Hope some of this helps!
Oct 17, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
My 1998 Ford Explorer runs rough under hard acceleration
New plugs and wires?
Double check to make sure that you've got the routing and firing order right... if you have 2 switched, the car may still idle well but then pop and sputter on harder acceleration.
The next step would be to run some "Complete Fuel System Cleaner"... If that's the problem, you should see results within 20 miles or so.
Apr 26, 2010 | 1998 Ford Explorer
Flat at acceleration, wont idle
Check the fuel filter to make sure it is not pluged up, also check fuel presure, if its ok you possibly have a pluged cat. converter.
Nov 26, 2008 | 1990 Chevrolet S-10 Blazer
4.9 liter will idle but wont accelerate have to start with ether
yes checked fuel pressure and replaced the fuel filter, checked the mapp sensor,tested throttle position sensor, has strong spark, 50psi fuel pressure, fresh tune up, runs real rich and rough idle but wont rev up like fuel injectors arent speeding up, also checked exhaust. thanks julius
Oct 09, 2008 | 1990 Ford F150
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
313 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
