Question about Garden
15-K119 Universal Lock-Out instruction manual
I have a duraband ht395 reciever and need the universal onn remote model ona12av058 code.. All the ones in the manual do not work? Anyone know this?
[PDF]Instructions - ONN Universal Remote Support
myonnremote.com/.../ONB13AV004%20Manual%20Version01.pdf
Mar 28, 2014 - will retain the codes you have programmed for up .... TV/DVD Combo, you might need to set up one ... Point the remote at the audio receiver,.
Faq - ONN Universal Remote Support
myonnremote.com/onn-faq.asp
How do I manually enter codes for my ONN Universal Remote? ... (You haveapproximately two seconds after the device shuts off or begins playing to lock-in the code.) ... so if you need to start the search again, it will pick up where it last left off.Missing: duraband ‎ht395 ‎reciever
RC: Durabrand codes one for all (Page 1 of 2) - Remote Central
https://www.remotecentral.com/cgi-bin/mboard/rc-one4all/thread.cgi?...
May 4, 2006 - 15 posts - ‎9 authors
Jan 25, 2016 | Televison & Video
The child lock is on my tv hitachi older model. i have no remote and the tv is turned off.. how do i get it back on to remove the lock???
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time.
Instructions
Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it.
Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000."
Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Oct 03, 2012 | Televison & Video
I locked my tv and dont have a remote how do i unlock it?
In life, simple yet unexpected events take place, such as the loss or an accidental breakage of the television remote. When a television is locked while the remote is missing or broken, it makes matters worse. Locks are placed on televisions for privacy or age-restricted viewers. To prevent a repeat of this event, store an extra remote in the house or business where the television is located. Without the original remote, some alternatives are available to remove the lock.
Difficulty: Moderate Instructions things you'll need:
  • Television manual
    • 1
      Read the manual. Televisions are accompanied by manuals when new. Some contain information on operating the television without the remote. Search for the "Lock" or "Privacy" section in the manual. If applicable, follow the given instructions.
    • 2
      Reset the television. You can reset and eliminate the lock on some televisions without the remote, using a few tactics. Hold the power button for five seconds. The television will automatically restart. If the lock is still on, unplug the television and remove the battery from the back panel of the television. Wait several hours before reconnecting the plug and reattaching the battery.
    • 3
      Purchase a universal remote. If the manual or resetting option does not work for your television, you need a universal remote. You can get one of these in electronics stores or online. The universal remote supports most televisions. The universal remote manual is included in the purchase and will instruct you on installing it into the television. After installation, enter the lock code using the universal remote.
May 09, 2011 | RCA 32F531T 32" TV
How do you scan for codes with universal remote 15-2147
i pulled these instructions directly from the manual:
1. Press TV once.
2. Press and hold P until the red LED blinks twice,
then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The
remote sends IR codes from its library to the
selected device, starting with the most popular
code first.
5. If the TV responds, go to step 6. If the TV does
not respond, press CH+. The remote will try the
next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps 1
to 6, substituting the appropriate key for the
device.
You can download the Full manual for FREE with Codes here: http://www.replacementremotes.com/MANUALS/Download-FREE-152147-User-Guide-Operating-Manual.html
Aug 11, 2010 | Radio Shack (15-2147) Remote Control
Need instlation insructions
Here's the installation and operation/programming instructions for your lock set.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Weiser and Kwik set both sold and marketed the same lock under their own brand names, as Weiser was the manufacturer, these instructions apply for your lock set.
Hope you find this Very Helpful and best regards!
Jul 30, 2009 | Kwikset 907 907-15 Satin Nickel Smart...
Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
fandrewszion
Jan 11, 2008 | Radio Shack 15-2200 Remote Control
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
