Question about Panasonic Viera TH-50PZ80U Plasma TV
Black vertical bar starts 11" from left, approx 3" wide and goes from top to bottom. Replaced TNPA4441 board, no fix. Disconnected ribbon to that section of plasma screen and bar turns white with color fringing. Bar present on all inputs and on screen displays. Set is 18 months old, so panel is warranty, but labor and other parts are not. Could this be from the D board? Connection from D board to buffer boards?
  • Jeffjo Sep 02, 2010
    I've just found some damage to the traces on the ribbon cable from the panel to the C2 board. The panel is NOT under warranty as this set was given as an exchange for an earlier set failure.
    I'm wondering if I trimmed the cable to where the traces as still good, cut off the tabs, and carefully reseated the cable if it might do the trick. Of course if the Drive IC is bad, the cable will probably fail again..The traces that are damaged are the first three of a group of 23 (the cable from left to right has the traces grouped as 1, 3, 23, 7, 23, 3, 2)
  • 2,326 Answers
Since you've replaced the C2 buffer board and didn't fix it. It's very unlikely but possible that the D board is defective. Visually inspect the solder joints on the D connector or try to press slightly on it; if pressing the connector works then there is a loose or cold solder joint on the D connector.
The screen should be replace since still under warranty. The price for a new screen might exceed the price of the plasma, even if you pay for labour still something to decide whether to fix or not.
Try contacting panasonic and ask them nicely if they would be willing to cover the labour cost as well.
Good Luck.
Posted on Aug 26, 2010
  • Jaime Hernandez Sep 04, 2010
    You could try cutting them very carefully as they can be easily damage. Try not to cut them more then 1.5 mm because you might not have enough expose copper to make a good contact with the connector on the C2 buffer board.
My LCD TV has a vertical line on the right side of the screen. What causes that?
Search Results
    how to fix horizontal or vertical lines on lcd tv - YouTube
    ? 4:52
    https://www.youtube.com/watch?v=k2QpYJp6MU8
    Apr 12, 2014 - Uploaded by cr4zyw3ld3r
    how to fix horizontal or vertical lines on lcd tv ... Bad T-Con/Mainboard(causes vertical/horizontal lines or half of thescreen is black)
    How to fix / repair vertical lines on half of LCD tv screen ...
    ? 5:23
    https://www.youtube.com/watch?v=8P_i-JIsrYA
    Jan 27, 2012 - Uploaded by chipotletv
    It shows how I fixed the vertical lines on the right half of a Samsung LCD screen tv. Music on video "Crazy ...
    how to fix led tv vertical lines on screen 55 ... - YouTube
    ? 9:47
    https://www.youtube.com/watch?v=zE0eqB4Ppjw
    Nov 11, 2012 - Uploaded by LUFERQUINT
    HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ... YOU MAY HAVE, GIVE IT A TRY BUT DO IT ON YOUR OWN RISK!
Jan 26, 2016 | Televison & Video
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
I have a Samsung model HLS5085WX/XAA. We have black specks all over screen and black horizontal lines approx 4 inches a part all the way across the screen
All Plasma and LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them. Good luck in rectifying the fault.
May 17, 2011 | Televison & Video
I have a NEC plasma tv which until recently played dvd/videos etc without problems. It then have lines going across the screen and sometimes just black out on the screen. We had the dvd/video player...
All plasma an lcd TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable.
Hope this help in solving the problem.Take care.....
Sep 16, 2010 | Televison & Video
Samsung lcd ln-s3641dx/xaa four bars on screen about one inch wide from left to right picture is visible in them but looks like dots in some of them
All lasma an lcd ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Aug 15, 2010 | Samsung LN32A330 32 in. LCD TV
Has a 2.5inch vertical black line about 3/4 from the left hand side its a panasonic TH50PX80A Thank you
Good luck.
Aug 03, 2010 | Televison & Video
A black line running verticall down the middle of
There is no invertor board on a plasma tv. The fault is the X address buffer board. This is located on the bottom of the screen and runs horizontally the whole width of the screen. If you remove the heatsink plate that covers the x address boards and you need to look at the screen ribbon at the same position as where the bar is (in the middle).Vary gently lift the Xbuffer ribbon lock and gently take out the ribbon.Clean the contacts very carefully with a fibre pen or an electrical cleaning fluid.Insert ribbon back and heatsink and check.Here is a picture of the board and ribbon
a 1 inch bar is associates with 1 ribbon fault. So if the bar was 3 inches in from the left of the screen, the faulty ribbon will be 3 inches in from the right working from behind the TV. If cleaning dont cure the fault, then the Buffer IC will be blown and order a new centre buffer board (you can buy off Ebay)
Feb 17, 2010 | LG 42PG20 42 in. Plasma HDTV
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Black line on Panasonic Plasma
go here and follow, it will work!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Sep 20, 2007 | RCA L26WD26D 26 in. LCD TV
Panasonic Viera TH-50PZ80U Plasma TV Logo
361 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
