Question about HP iPAQ H5550 Pocket PC
HP iPAQ 5555
I am unable to input any data onto my calendar. I can pull up the calendar itself, but can't edit or add any new information, and cannot change from the current date to any other date or view (such as the week, month, or yearly view).
  • Bart840 May 10, 2008
    I actually fixed it myself before the solution was posted, by performing a forced reset. Now it works good as new.
Please, help me how to hard and soft reset for my ipaq H5550 .
Thank's and regards Rony
Posted on Oct 10, 2008
After full reset I am unable to access online capabilities
Posted on May 08, 2008
Tip
HARD RESET HP iPAQ h5000 Series 5450,5550 5555 HP h3800 Series 3830 3835 3850...
While holding down on the far left (calendar) and far right (iTask or Today) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. After you see the screen fade, you can verify the hard reset by pressing the power button. If the device does not power on, then you have successfully reset you unit. To reactivate the battery you must either connect the iPAQ back to AC power or press the reset button again with your stylus
on Mar 10, 2010 | Cell Phones
How do I get dashes inserted into my long phone numbers?
Well it should do it by itself,but if not then when your typing in the number ,switch to symbol mode by using the star key..then you can add your dashes
Jun 01, 2010 | Motorola Mobility RAZR V3
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
Contacts and Calendar buttons don't respond
I did a hard reset and the problem was gone (I've lost all the calendar and contacts data but they were restored after making the synchronisation)
Jan 07, 2010 | HP iPAQ rx5915
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Hx4700
You need to sync the old one with your PC, then simply set up a new partnership with your new Ipaq and sync it with that same PC.
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
HP IPAQ 5555 1.10.13 ROM UPDATE
I thought my 5555 with 1.10.10 was the latest and most stable?? How come i didnt know about 1.10.13 ROM Update... Anyway, i think it is your Camera Update that causes it. But to confirm, which ROM are you using now? Go to "Start" >> Settings >> "Asset Viewer" >> Under Version >> check the ROM Revision. 1.10.10 had no major problems, only sometimes when i couldnt connect to my wireless router / bluetooth problems, but now it is okay, dun worry.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
HTTPS web sites
 IE can be updated from microsoft or manufacturers site. DeviceMosaic, Proxiweb, netfront are other browsers that supports https sites.
HP iPAQ H5550 Pocket PC Logo
180 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
