Question about Kenmore Kitchen Ranges
I have an error message and cannot get it to reset. The message is 5A6 6ATH. This came up after we had a power outage and I was trying to reset the clock. I have flipped the breaker, no change. This is a Kenmore Elite Electric smooth top double oven range. I can still use the stove, but the electronic buttons for the ovens and clock do not work and this error is on the display.
  • tasker165 Sep 07, 2010
    I learned that it does not say 5A6 6ATH. It says SABBATH. It is not an error I accidently set it to SABBATH mode and after 72 hours it came back to normal. When I realized it was not an error I looked through my manual and sure enought there is a delay mode called SABBATH for the Jewish Sabbath where they cannot work. We had tried unplugging it, tripping the breaker nothing worked. Once I knew what it was saying, my manual explained out to remove it.
I have the same problem, if you figure it out please post it.
Posted on Sep 06, 2010
  • shawna2 Sep 06, 2010
    We just got ours to work, We unplugged it for about half an hour, once the error code was done we hit the clock button until the clock came up and it worked again. I hope this works for you.
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Error message
try resetting the 40 amp double breaker in the panel
Nov 19, 2013 | Kenmore Frigidaire Glass Cook Top...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
Error code 78
Usually a result of a sudden power outage. Majority of the time it can be reset without replacement of the fuser. Here is an article I wrote explaining the cause and how to reset the message.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/28/brother-fax-mfc-76777879-fuser-errors/
Dec 06, 2010 | Brother MFC 8300 Laser Printer
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Error message EA3
Bump this have same problem
Apr 27, 2009 | Office Equipment & Supplies
Power outage caused printhead error on HP 1055 CM design jet
turn off the printer, remove your jetdirect card(nic) sounds like your local tech doesn't know his **** from a hole in the wall. this should resolve your loop problem, if not then your main pca have been popped by the power outage. good luck.
Apr 22, 2009 | HP DesignJet 1055cm InkJet Printer
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
Kitchen Ranges Logo
372 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
